BAD CDI ON MY 02' 426
4 replies to this topic
  • GNCCJON
Posted April 18, 2002 - 02:17 AM
Has anyone else had problems with there 02'??
  • Sparky_So_Cal
Posted April 18, 2002 - 06:17 AM
i have had mine since 12/01 and haven't had any issues, did yours go bad?
  • Hootna
Posted April 18, 2002 - 07:05 AM
Have you checked all of the readings with an Ohm Meter. I know my CR ignition crapped out 2 weeks after i bought it. I pulled apart everything checked everything with an Ohm meter and found aqll to be ok. I reassembled and it miraculously began to work.
Have you checked your ignition on a buddys 426 if possible and vice versa?
Sometimes the Kill button shorts out or it could be a bad stator but you should be able to check that with an Ohm meter also.
Well good luck.
  • PK
Posted April 19, 2002 - 10:26 AM
I haven't had any problems on mine. What symptoms are you seeing that lead you to the CDI? Is Yamaha gonna fix it for ya?
PK
  • leatherlungs426
Posted April 19, 2002 - 11:32 AM
I am curious what the date on the steering stem has to be to classify it as a 2002?. Mine has 08/01 on it. :)
  • Hot  36 replies
  • 10 replies
  • Hot  113 replies
