XR600 Fork Springs Length
1 reply to this topic
  • Rhino
Posted March 24, 2004 - 05:54 AM
I've done a lot of research on fork springs and I guess I've confused the XR650 fork springs from the XR600 fork springs.
I've ordered the Eibach fork springs and it turns out I have to use a spacer (pvc pipe cut to fit :)) to make the springs fit for my XR6. Is there a fork spring out there that will fit my '94 XR600 without a spacer.
I'm not too worried about using a spacer, I was just thinking that Eibach made a fork spring that would drop in and replace the stock spring.
Anyone found a fork spring that matches the stock? I would appreciate any info on this.
Thanks
  • POBLondon
Posted March 24, 2004 - 11:35 AM
The XR600R and XR650L kits are the same part number - I have the same kit.
I believe it's standard practice to use a spacer (the PVC pipe) to preload the spring. I am fitting mine in a day or two.
The instructions tell you how to set the oil level, etc.
HTH :)
Drop me an email if you want me to forward the instructions / take pics of me fitting them in the next few days.
:D
