Nitrogen pressure on rear shock?
8 replies to this topic
  • Dan_YZF
Posted April 09, 2002 - 02:56 PM
I'm on a servicing rear shock job...what is the recommended nitrogen pressure to put in a 2000 YZ426 rear shock....
It was 90 lbs/sq inches at disassembly...seem pretty low to me....
Oh I'm 195lbs hare-cramble/trail rider if it's valuable info
Thanks
Dan
[ April 09, 2002: Message edited by: Dan_YZF ]
  • yamie_rider
Posted April 09, 2002 - 03:00 PM
Take it to your dealer, they will do it for FREE
  • teamtoxic
Posted April 09, 2002 - 03:22 PM
Stock the nitrogen is pressurized to 147 psi in the shock bladder but you can go a little higher than that. I just did mine the other day and went with 155 psi.
TT
  • motoman393
Posted April 09, 2002 - 03:30 PM
stock pressure is like 148 psi, Race Tech recommends 175 psi w/the gold valve (to help the seal head seal better). Dont try to check your pressure after you fill it or you will lose 15-20 psi just by checking it!
  • osheen
Posted April 09, 2002 - 06:26 PM
Somebody told me 175 a long time ago and that's what I've been running ever since....
  • 98yz
Posted April 10, 2002 - 06:03 AM
I run our race tech stuff at 175. My GP-Racing done suspension is also at 175.
  • sirthumpalot
Posted April 10, 2002 - 06:15 AM
Do you guys find that the pressure drops as the years and miles go by?
  • osheen
Posted April 10, 2002 - 02:24 PM
Yes, it will drop.......
  • Dan_YZF
Posted April 10, 2002 - 04:06 PM
Ok
Thanks all, I'll go for 160-170...stock valving
BelRay HV1 5wt
Dan
