Lowering Strut
2 replies to this topic
  • eastcoastguy
Posted March 20, 2004 - 02:28 PM
any good recomendations on a lowering strut for 2004 WR 450
  • Indy_WR450
Posted March 21, 2004 - 05:16 AM
No linkage is available yet. You can order a custom length spring. 1" - 1.5" shorter and stiffer. Your sag will be higher than normal but you will still have some decent suspension travel. Raise the forks in the tubes 3/4" as well or have thew tubes cut down an inch as well. :)
  • Gadsen
Posted March 21, 2004 - 05:21 AM
Take one of your original links out and just have a piar made, except add some space between the holes (longer). Find a local small machine shop. Otherwise, thje spring option above is probably the only other way until someoen builds longer links? :)
