  • Instagram
2016 WR450F 14 Tooth CounterShaft Sprocket
  • Please sign in to reply
9 replies to this topic
  • Ka0sX
Posted October 14, 2016 - 03:34 PM
Hey guys just wondering if a 14tooth will fit with the stock case save that is installed on the bike? Dont want to have to grind down the case saver
Thanks
  • Macsplace
Posted October 14, 2016 - 06:04 PM
Unfortunately a 14 tooth will not fit with the OEM case saver without some grinding. I am using the OEM inner metal case saver but had to slightly enlarge the bottom bolt hole and elongate the top bolt hole so it would fit with a 14T sprocket.  In the photo I left out the top bolt so you could see how much material to remove if you want to use the OEM part.WR Case.JPG
  • Ka0sX
Posted October 14, 2016 - 06:31 PM
Unfortunately a 14 tooth will not fit with the OEM case saver without some grinding. I am using the OEM inner metal case saver but had to slightly enlarge the bottom bolt hole and elongate the top bolt hole so it would fit with a 14T sprocket.  In the photo I left out the top bolt so you could see how much material to remove if you want to use the OEM part.attachicon.gifWR Case.JPG
I wonder if an after market case saver one would work ?
  • Macsplace
Posted October 14, 2016 - 06:47 PM
Possibly, you may want to email whatever company you choose and ask them if their case saver would fit with a 14T sprocket. Maybe someone else will respond with some additional info.
  • Krannie McKranface
Posted October 14, 2016 - 07:13 PM
You just buy the one made for 14t.
It is usually listed.
  • knuckleduster271
Posted October 16, 2016 - 06:26 AM
I run a tm design plastic case saver- fits a 14 t no problem
  • foggy3061
Posted October 17, 2016 - 11:22 AM
Thanks
Or you could make your own case saver for the 14t.......
I made one as there were very limited options when i bought the bike.
  • Ka0sX
Posted October 28, 2016 - 12:49 AM
hey guys just an update, Tearing bike down for some work greasing etc, Need to change tires tubes etc,
So wondering since i cannot fit a 14T front what would be the equivalent to a 14F 50R ??
Think the opposite  12F 52R ??
Thanks
  • YZEtc
Posted October 28, 2016 - 01:52 AM
13/46
or
12/43
12/52 is much lower gearing than 14/50.
  • craig652
Posted October 28, 2016 - 09:23 AM
If you like the original gearing then I'd go 13/47....
this website is helpful     gearingcommander.com
Thanks
