2009 yz450 to 2013 450 fork swap?
7 replies to this topic
  • Gclaxton
Posted October 12, 2016 - 02:47 AM
So there's a guy near me parting out what looks to be a mint 2013 yz450. Was wondering if the front forks would fit on my 2009 and if there would be any benefit to doing so. Anyone else done this?
  • Krannie McKranface
Posted October 12, 2016 - 05:02 AM
Same forks.
  • Gclaxton
Posted October 12, 2016 - 05:03 AM
Thanks a lot buddy! Probably gonna pick them up then.
  • Gclaxton
Posted October 12, 2016 - 09:59 AM
Any idea what they'd be worth?
Posted October 13, 2016 - 05:51 AM
They are not identical, and you could run into a misfit here and there by mixing parts.  Using the complete set will probably work fine, though.  But they're worth upwards of $400, and except for the fact that the springs won't interchange, and the valving is going to be a smidge different, they won't be a significant improvement over the ones on your bike unless those are damaged.  For half the cost of the used '13's, you can probably get yours revalved to suit you and end up with a better result than with the used set.
  • Gclaxton
Posted October 13, 2016 - 05:55 AM
Thanks for the info. The ones on my bike are valved and set up for my weight but leak a small amount. The ones he is parting out just look cleaner and newer so I was just thinking about getting them for a newer look. Sounds like it would be more trouble than it's worth though. Thanks man.
Posted October 13, 2016 - 05:59 AM
More money than trouble, but they'd be stock versus a custom setup.
  • mikedabike
Posted October 14, 2016 - 03:12 PM
The upper fork tubes are 2mm smaller diameter on the 13. You would need the triple clamps too.
  • 5 replies
  • Hot  50 replies
  • Hot  36 replies
  • Hot  38 replies
  • On January 15, 2017
