2007 yz450f hard to start now
9 replies to this topic
  • ducky2004
Posted October 11, 2016 - 05:47 AM
Hey guys ... just wanted to check to see if I'm missing anything.
I just had the bike into the shop to replace my crankcase cover due to it being cracked from the guy I got it from. The replaced the bearings, piston rings and all the gasket while they were in there. While the bike was at the shop, I took the opportunity to clean and rejet the carb for the exhaust he put on. It was running a little lean. I also put a fuel mixture screw and the boyesen quick shot 3.
Before I took it in, the bike relatively easy after just a few kicks with the it choked. Now it takes forever even with the choke. I found that if I hold the throttle open it will normally start after a few kicks, but that doesn't seem normal.
What would be causing this? Is it the carb tuning or valve issue?
Once the bike is running, it runs great. I have about 10 hours on the bike since the work was done.
  • ScrewMx_Hd
Posted October 11, 2016 - 05:56 AM
check the valves
  • ducky2004
Posted October 11, 2016 - 06:03 AM
Could being too tight result in that? Is there an easy way without taking the top cover off?
  • jscoot116
Posted October 11, 2016 - 06:08 AM
Timing off a little. That's my guess
  • ducky2004
Posted October 11, 2016 - 06:38 AM
Yeah my gut tells me something like that too. I just don't want to tear the bike down to fix the shops mistakes again. Live and learn I guess
Posted October 13, 2016 - 05:57 AM
It's more likely the carb than anything, and if it likes the throttle slightly opened during starting, it usually indicates a rich condition.  Try the fuel screw in a half turn from its current setting to begin with.
  • ducky2004
Posted October 13, 2016 - 12:54 PM
Thanks! That would be ideal! I'll give that a shot
  • ducky2004
Posted October 13, 2016 - 12:56 PM
Would having the quick shot on the carb be causing it too? That replace the leak valve, so I don't think that would affect starting
  • Krannie McKranface
Posted October 13, 2016 - 02:06 PM
It can affect starting, but only if you grab several hand fulls of throttle before starting, squirting too much gas into the intake.
Unlikely the issue.
  • ducky2004
Posted October 13, 2016 - 02:51 PM
Cool thanks...will try the fuel screw, then tackle the timing and valve clearances
