  • Instagram
Related Garage
Yamaha YZ450F (2010)
Owner: Dmeiborg
Added on Yesterday, 07:30 PM
Related Reviews
Yamaha YZ450F 2011
Last review by Le_Racer
Yamaha YZ450F 2008
Last review by Metzman
Last review by Tommyk_55
Yamaha YZ450F 2003
Last review by Garrett Canada
Yamaha YZ450F 2005
Last review by 2fast4luv
2013 yz450f on off throttle jolt
29 replies to this topic
  • olgus69
Posted October 08, 2016 - 06:47 PM
Hi guys i have been playing with my yz for a while trying to sort out the on off throttle jolting (not sure the proper term used). I am running 14 50 gearing i have added a 9 ounce flywheel and a G2 throttle using the 200 cam. I can't remember the map I'm running pretty sure it was the more sedate tune. Im just playing around with some cross training and enduro. My mate has the 13 wr450 which i took for a spin and noticed the throttle comes on from nothing to very smooth transition apposed to mine from nothing to instant power. Is there something i have over looked or is that just as close I'm going to get to the smooth rollin like the wr. I am not in the position to buy a wr and i like the feel of the yz. This is the only problem i have.Thanks for any advice.
  • olgus69
Posted October 08, 2016 - 09:33 PM
Would it be as easy as replacing throttle body with a wr450f throttle body?
  • Krannie McKranface
Posted October 09, 2016 - 05:17 AM
Just change the map.
Tons of info on this if you search.
You might also need to recalibrate the CO level at idle, as the first range of FI bikes this was not done very well at the factory it seems. Easy to do.
  • olgus69
Posted October 10, 2016 - 12:31 AM
I have played with maps with no joy. How do you adjut co level and what does it do.
Edited by olgus69, October 10, 2016 - 12:31 AM.
Posted October 10, 2016 - 05:01 PM
So, you have gone to -6 on the IGN, and +6 on the fuel for idle and partial throttle at all rpms?
You might need a longer throw throttle, like what is on the FX and WR.
That is what I usually do to track bikes to make  them smoother.
G2 Throttle Tamer
  • kxfreak
Posted October 14, 2016 - 09:11 AM
I've had really good results using the g2 200 cam throttle tamer, and the "smooth" map. but I also run a gytr head and full fmf 4.1 system. but by using the right map it makes a huge difference for me personally
  • Zackdocks
Posted October 14, 2016 - 09:42 AM
Its the throttle body, look into sending it to injectioneering for modification.
Posted October 14, 2016 - 11:50 AM
That is the most complete and direct fix for it.  The benefit is that it stays fixed regardless of the mapping used.
  • kxfreak
Posted October 14, 2016 - 02:26 PM
hey gray, I had been seeing this talk about the injectioneering mod for the throttle body ever since I came back back to thumpertalk a few months back. I was wondering if you or anyone else here has had this done and what the turn around time was for you? I know it can vary but I searched there site and on here for an answer and couldn't find one unless I missed it? thanks and sorry I'm not trying to thread jack.
  • olgus69
Posted October 14, 2016 - 03:56 PM
Ok so injectioneering? Is there any where here in oz that does this? Also how come when i rode my mates same vintage WR it was perfect. Are the 2 throttle bodies different ? Are the swappable?
  • stevethe
Posted October 14, 2016 - 05:03 PM
Same throttle bodies the WR one has a throttle stop screw. Put less timing and add more fuel especially the first left lower numbers in your tuner.
  • olgus69
Posted October 14, 2016 - 05:45 PM
Ive just done +7 FI and -7IG and still has that off on feel from idle also have the G2 tamer with 400 cam which smooths the power band out but not that initial response.
  • stevethe
Posted October 14, 2016 - 06:27 PM
Hum I am running the Hinson momentum clutch basket that might help some.
Posted October 16, 2016 - 04:38 PM
Turnaround time has been what has hurt the company, according to what you find here.  I still have the carb.
My understanding is that the closed angle of the throttle valve is changed, and that it's more complicated than simply re-cutting the valve.
  • Ride_Flip_Repeat
Posted October 20, 2016 - 10:18 AM
Sorry complete noob here when it comes to the 450f and mapping. I am researching in addition to posting. I have a friend with a 2012 and now I have a 2013. He has the GYTR system and he has been messing with his mapping as well. He has mentioned this tamer because he is experience the jump problem. Does anyone have the link to get to the service part of G2? I would be interested in this.
Also I am running all stock including mapping besides fmf 4.1 titanium pipe and the titanium mega bomb. Riding at 0-1000ft, 45f and lower and trails hard pack, rocks/roots. Could you please recommend a mapping setting or point me in the direction? Thanks.
Alright, figured out how to navigate the site. Now for the type of riding I do. Which cam size would be best? I cruise through the woods but would still like control and like the throttle to be smooth.
Edited by Ride_Flip_Repeat, October 20, 2016 - 10:27 AM.
  • WouldsAssassin
Posted October 26, 2016 - 05:38 PM
I would recommend going the opposite direction with fuel and ignition. Try the slippery conditions map. It helped me. Also raise the idle slightly higher than recommended that way the throttle is a little more open than would be at the normal engine idle speed. That made a huge difference.
I priced a 16 WR throttle body and may try swapping it if I get the disposable income.
The CO settings can only be done with the Yamaha Fuel injection diagnostics tool.
  • olgus69
Posted December 30, 2016 - 05:04 PM
Ok so I have tried this and no difference.
Have you tried the wr throttle body yet?
I really want to get to the bottom of it as i have invested quite some time and money it now. Would the Fx throttle body be better???
Posted December 30, 2016 - 05:14 PM
It's the same
  • olgus69
Posted December 30, 2016 - 05:18 PM
Is there a place that mods the throttle bodies here in Oz? Im in Karratha and theres no place around that does dyno tunning to sort it. I really hate it at low speed and wish there was a cure.
Does anyone know if the 14 15 or16 models have this issue??? Mines the 13 and a mate had the 11 with the same issue.
  • wes513v
    Crotchety Old Fart
Posted December 30, 2016 - 06:30 PM
Go to a 49, or even 48 rear sprocket, remap, add a Dr. D pipe.
  • Hot  36 replies
  • Hot  47 replies
  • 10 replies
