Front brake won't build pressure after crash
5 replies to this topic
  • ayz250
Posted October 01, 2016 - 03:56 AM
I slid out in a corner and the front brake lever must have caught the ground. Now the front brake won't work or build any pressure. My question is did it get air in it and needs to be bled or did I ruin the master cylinder? Any advice would be great thanks.
The bike is a 2012 yz450.
  • CR250_182
Posted October 01, 2016 - 05:43 AM
Check the line for any little holes, also check the seal where the lever is.
  • WALKINGWOUNDED
Posted October 01, 2016 - 09:30 PM
Usually it's the master cylinder.
The rubber seal on the piston gets "peeled backwards" and it won't hold pressure.
  • Slow and Jerky
Posted October 02, 2016 - 03:50 AM
Check your front brake rotor to see if it's bent. If the caliper piston got pushed in it can feel like it's not building pressure.
  • ayz250
Posted October 02, 2016 - 01:34 PM
I figured out what happened. I must have hit the bolt holding the line coming into the master cylinder. It was just loose enough to not hold pressure. Tightened it up now I just gotta get the air out of the line.
  • cowboyona426
Posted October 03, 2016 - 03:51 PM
I recently had a similar experience, tipped over in some rocks and when I picked my bike back up realized the front brake lever went straight to the bars.  The banjo fitting at the caliper had been knocked loose, I got lucky and was able to just tighten the bolt back down and the brakes worked fine.
  • Hot  30 replies
  • Hot  50 replies
  • Hot  36 replies
