  • Instagram
Related Reviews
Yamaha YZ450F 2016
Last review by Goof331
Yamaha YZ450F 2004
Last review by 1trackmind
Yamaha YZ450F 2015
Last review by JuanPAguilera
Yamaha YZ450F 2009
Last review by w5rjh
Yamaha YZ450F 2008
Last review by thaoe_thumper
Related Garage
Yamaha YZ450F (2004)
Owner: 1trackmind
Added on November 29, 2016
Newer DID chain,, now link each side of master are very stiff.
  • Please sign in to reply
9 replies to this topic
  • ttreewalkerr
Posted September 30, 2016 - 03:21 PM
About 600 miles on new chain and noticed each side of master link is stiff. Not the pivot at the master, but next pins. I see a larger gap on the pins.... is this thing trying to come apart ? It's not a corrosion thing......
Anyone see this before ?
  • Krannie McKranface
Posted September 30, 2016 - 04:26 PM
DID makes a wide range of chains.....from OEM chains that last 10 hours to the VT-2 industrial strength X ring chain.
Too many factors to make a blanket statement about chains.
If you did not change your worn front and rear sprockets when you changed your chain, you chain will wear out quickly. Very quickly.
  • ttreewalkerr
Posted September 30, 2016 - 05:37 PM
All were new together. I'm assuming this chain is toast. Just don't know why. I don't tighten it stiff, always some play.
  • ttreewalkerr
Posted September 30, 2016 - 05:38 PM
Sprockets are like new,, 600 miles on the set. I could grind out 1 link and put my wheel all the way forward,, but other side of link is same.
Posted September 30, 2016 - 06:38 PM
So you must have purchased the DZ version.
It's junk.
  • ttreewalkerr
Posted September 30, 2016 - 07:17 PM
DID 520 ERT Gold Chain 120 Links
Posted September 30, 2016 - 08:32 PM
That's a decent chain.
Not sure what to say, other than you have an alignment problem, or you are not oiling the chain enough.
  • ttreewalkerr
Posted October 04, 2016 - 03:28 PM
Krannie, it was a DZ after all,, noticed when I removed the chain.
Posted October 05, 2016 - 06:37 AM
Yeah, sorry to say that the DZ chain is the 'throw away' chain supplied on some new bikes.
I would try a VT-2 if you can afford it.  I get hundreds and hundreds of hours for trail riding and at least 50 for desert for racing.
It is an X-ring chain, it is heavier, and it does change the rev speed a tiny amount.
Make sure it does not rub the case, and add a 1mm washer if it does. I'm not sure which bike you have....but on 2006+ it does not rub with the stock CS sprocket.
  • ttreewalkerr
Posted October 05, 2016 - 07:37 AM
I got the RK X chain, high tensile strength.
  • 5 replies
  • Hot  47 replies
Motocross
  • Hot  491 replies
