  • Instagram
Putting a YZ transmission into a WR
  • Please sign in to reply
16 replies to this topic
  • aldean
Posted September 20, 2016 - 05:35 AM
I have a 2003 WR450f and damaged the transmission. I have searched online for an affordable used transmission and have only come across a YZ and not the wr tranny. Is it a perfect swap ?
Can I simply remove my old wr transmission and pop in a YZ transmission and get a smooth working bike once again?
  • cjohnso
Posted September 20, 2016 - 05:58 AM
It will most likely fit but the gearing will be different.
  • ttreewalkerr
Posted September 20, 2016 - 03:47 PM
I know the shift forks are the same part numbers.
  • Just_a_trail_rider
Posted September 20, 2016 - 05:28 PM
isn't the yz tranny for 2003 a 4 speed?
  • cjohnso
Posted September 20, 2016 - 06:23 PM
It shows 5 gears in bikebandit
  • bikedude987
Posted September 23, 2016 - 01:26 PM
it will work, but you'll get the close ratio yz gearset, not the wide ratio wr gears...
  • jamesm113
Posted September 25, 2016 - 09:15 AM
my friend has an 03 yz450f.  it's a 4 speed
  • ttreewalkerr
Posted September 25, 2016 - 11:22 AM
Your buddy toasted his 5th gear,, that's why he thinks he has a 4 speed. Sure I believe him he really does have a 4 speed.
  • DeepPurplishBlue
Posted September 25, 2016 - 12:04 PM
2003 Yamaha YZ450F Specs
    Engine:Type: 449cc, DOHC, 5-valve, liquid-cooled four-stroke w/ titanium valves
    Bore x stroke: 95x63.4mm/3.74x2.5in
    Compression ratio: 12.5:1
    Carburetion: 39mm Keihin FCR Flat-side w/TPS
    Transmission: Constant mesh 4-speed, multi-disc wet clutch
    Starting: Kick
Edited by DeepPurplishBlue, September 25, 2016 - 12:51 PM.
  • jamesm113
Posted September 25, 2016 - 12:29 PM
http://www.partzilla...SION/parts.html
There's no 5th gear.  Not sure how big of an issue it will be for OP.  My buddy could still keep up in the open washes
  • knuckleduster271
Posted September 26, 2016 - 05:35 PM
You will have to change the mainshaft that your sprocket bolts to ad the pinion for first gear is machined into the shaft.
Depending on what you use the wr for a yz swap may or may not be right for you-
If you ride technical trails or tight single track the yz first gear isnt ideal- if you ride the bike on the road the yz 5 th gear is shorter than the wr.
On my 07 i built a hybrid yz/wr transmission using the yz 1-2-3 and the wr 4-5 gears.
My bike is a street titled motard that sees track time. The yz 1-2 gear is perfect compared to the wr on a closed course- with the wr 4-5 gear i can still reach above 100 mph on top.
  • underground-mpyre
Posted September 26, 2016 - 06:12 PM
I would buy the oem gears and fix the gearbox. Close ratio sucks in the woods with a lot more shifting and feels like a dragster than a solid tractor.
  • knuckleduster271
Posted September 26, 2016 - 06:33 PM
Thats a great explanation.
The transmission is really yamahas weak link in these bikes to be honest- if it were me i would take underground's advice and buy new because you could potentially be going through this again in the nearfuture with used parts.
  • aldean
Posted December 14, 2016 - 05:02 PM
Solved it. Apparently mistakenly mounted the housing for the starter in reverse this changing the polarity of the magnets causing the starter to work in reverse. Turned it the right way now and works fine.
  • dg400sm
Posted December 15, 2016 - 03:56 AM
i have a wr450 and a yz426. the close ratio gearbox is what makes the YZ the worst bike i have ever owned
Posted December 15, 2016 - 02:55 PM
The '03 WR450 is a Gen1 450.  The only bolt-in transmission swap for this bike from any YZ450 is the Gen1 '03-'05, and that is a 4 speed.  Won't do any good to argue that it isn't; it is.  The shift forks are not the same part numbers, either; there's only two of them, vs. 3 in the 5 speed, and obviously the shift cam is also different.
It is possible to install the 5 speed from a YZ426, but you'll be doing some machine work to make it fit.
  • zibbit u2
Posted December 17, 2016 - 12:45 AM
Deleted response..
Read the whole thread, the problem was solved.
Edited by zibbit u2, December 17, 2016 - 12:47 AM.
