Clutch basket problems
15 replies to this topic
  • FatCowKiller
Posted September 14, 2016 - 04:02 PM
So I need quick advice as I have to put my bike back together soon, I took the basket out because the clutch was sticking and not letting me switch gears without significant force. Upon inspection the friction plates are within specs and the basket grooves are very slim as it is not extremely rigid. Should I file them down?
  • stevethe
Posted September 14, 2016 - 06:37 PM
Probably just have warped metal plates causing clutch drag. When replaced with factory Yamaha plates it is usually fixed.
  • FatCowKiller
Posted September 14, 2016 - 07:14 PM
The problem is that none of them are warped as I checked the mall thoroughly, new problem as I was putting the head of the basket back on one of the heads bolts that go in the spring broke off (exploded off) before I even put it to the specified torque setting :(. Now the bottom half is stuck inside (sobs* cries*).
-Now I am leaking oil
-Also clutch lever has no pressure and I can no longer change gears to move it :(
  • redhurricane
Posted September 15, 2016 - 11:55 AM
Personally I would have spent the time to file the basket fingers since you already had it out.
A factory service manual is your friend, do you have one? Not sure how you break a steel bolt head off on something that threads into aluminum.
  • FatCowKiller
Posted September 15, 2016 - 07:59 PM
unfortunately I was short on time and I didn't want to accidentally make the basket worse if I could avoid it, I have the pdf it's just irritating to read through because of all the different languages taking up majority of the pages. I had it torqued to spec and as I was tightening the last couple the first one I torqued just blew apart. It was pretty weird and it definitely wasn't over torqued. I've noticed alot of the screws on my 04 wr 450f have been pretty cheap, I don't know if the previous owner replaced them or not but they are all extremely soft and do not seem to be high quality so this isn't the first time on this bike where I've had to replace some bolts/screws.
Edited by FatCowKiller, September 15, 2016 - 08:00 PM.
  • Krannie McKranface
Posted September 16, 2016 - 05:31 PM
You can't use a 'regular' torque wrench for under 15ftlbs.
Must be designed for 2-25 ft lbs.
Otherwise it will be only  +/- 30% accurate, and you will snap off bolts.
  • FatCowKiller
Posted September 19, 2016 - 02:36 PM
it was a special one rated for 0-25, So I found some replacement bolts and was able to back out the bolt that broke off. I was hand tightening the screws very meticulously to ensure that no more mishaps would happen when another one of the heads exploded off and they were only about halfway in......... does anyone know of a problem with the bolts breaking so easily? it seems like every bolt and screw on the wr is super cheap. Should I replace the rest of them? as I fear they will break off when i'm driving.
  • stevethe
Posted September 20, 2016 - 05:00 AM
Installer error previous over torqued and stretched bolts. Replace.
  • Agazza
Posted September 21, 2016 - 11:46 AM
Replace and use momentum wrench
  • FatCowKiller
Posted September 23, 2016 - 05:36 PM
Ok, so I'm trying to find replacement bolts for these does anyone know the hardness of the stock ones???? I'd rather not pay an arm and a leg because the prices for these online are quite high and if I could replace these easily at a hardware store I would much rather. I also saw a kit for a 2003 clutch with bolts and springs relatively on the cheap, the 03 should fit the 04?
Edited by FatCowKiller, September 23, 2016 - 05:38 PM.
Posted September 23, 2016 - 05:56 PM
Grade 3 is fine.
You count the lines/dots/symbols on the head of the screw to determine it's rating, if there is no number
Gonna be hard to find at a hardware store, that long, with a shanked shaft.
Go to Partsfiche.com
  • FatCowKiller
Posted September 23, 2016 - 06:27 PM
They have them there but they want me to sell my house to pay for the shipping ($11) which is completely stupid and outrageous. I found 8.8 zinc plated steel ones at the hardware store which is equivalent to grade 5??
Edited by FatCowKiller, September 23, 2016 - 06:28 PM.
  • FatCowKiller
Posted September 23, 2016 - 06:32 PM
In addition to the last post will friction plates from an 09 and 03 fit a 2004? They look exactly the same in the pictures and I don't see anything online that says they changed the shape or size.
Posted September 24, 2016 - 06:09 AM
I guess I am not a cheap as you....$11 to ship anything , anywhere, is very cheap.
Try driving it your self and see what that costs...
  • FatCowKiller
Posted September 24, 2016 - 06:39 AM
There are these  boxes called flat rate boxes that ship anywhere in the u.s for roughly  $7 I dont like supporting people with hidden costs
Posted September 24, 2016 - 06:50 AM
They probably use UPS exclusively, because USPS will not honor any insurance claims unless you go to court....
