Slipper Clutch for 2012 WR450F? YZF450 ATV? Adige?
14 replies to this topic
  • dirznut
Posted September 13, 2016 - 10:12 AM
Hello! I'm in search of a slipper that will fit my 2012, can anyone point me in the right direction? There are a couple take-off 2014-2016 YFZ450 oem slippers that the seller states fit our bikes, but are they really just drop-in?
Thanks!
  • stevethe
Posted September 13, 2016 - 10:27 AM
Thanks!
I'm not sure what your looking to slip. If it's a supermoto bike I would recommend a Hinson BTL slipper clutch. I use one in my supermoto WR450 and it works flawlessly.
Someone has used a YFZ and I believe it took a little work to make it fit. But I'm not sure of how well it would work.
  • stevethe
Posted September 13, 2016 - 10:41 AM
Some info. http://www.thumperta...lutch-in-my-wr/
  • Pinepig
Posted September 13, 2016 - 11:13 AM
Thanks!
In a 12,  yes,  straight drop in,   you will need the entire clutch assembly,  plates/frictions all of it.
  • dirznut
Posted September 13, 2016 - 12:44 PM
Is this all I would need? Thanks!
http://imgur.com/a/z3jrL
Or would I also need the basket, thrust, etc?
Edited by dirznut, September 13, 2016 - 12:56 PM.
  • Pinepig
Posted September 13, 2016 - 01:01 PM
It slides right into the stock basket.    You'll need the bearing assembly that rides on the pressure plate at the end of the clutch pushrod too.   The hole in the center of the pressure plate that it rides in is slightly larger than the stock WR450 pressure plate.
  • dirznut
Posted September 13, 2016 - 01:14 PM
Thanks for all your help.
http://imgur.com/a/TDAvo - YFZ clutch microfiche
Just need #24? Or #24-#26?
Edited by dirznut, September 13, 2016 - 01:16 PM.
  • Pinepig
Posted September 13, 2016 - 02:05 PM
23-4-5-and 6.
  • dirznut
Posted September 14, 2016 - 06:45 PM
Ordered! I'll post back when the parts get here and document the drop-in!
  • Pinepig
Posted September 14, 2016 - 08:49 PM
Somebody has to do it,   I'm such a lazy F*!(
  • trm122
Posted September 19, 2016 - 10:51 AM
Any update?
  • dirznut
Posted September 20, 2016 - 10:12 AM
Slipper came in, waiting on corresponding YFZ parts. Fingers crossed!
  • dirznut
Posted September 22, 2016 - 08:13 PM
Update-
I'm mid install and I'm a bit stuck. The WR push rod head is hollow with a ball bearing inside. The YFZ push rod head is solid and does not seat far enough inwards with the ball bearing in place (usually the ball bearing goes inside the hollow WR piece). Do I just forego the ball bearing?
  • Pinepig
Posted September 23, 2016 - 05:07 AM
Update-
Try backing the clutch cable out fully to give the required space.   I had to adjust mine to a new position too.    The ball bearing is there in both setups if you look at the parts diagrams.
  • dirznut
Posted September 23, 2016 - 06:36 AM
I ended up not using the YFZ pushrod and reusing the WR pushrod. The YFZ is a solid piece where as the WR is a hollow piece. Since both use a ball bearing, the ball bearing sits inside the WR pushrod and shortens the whole pushrod assembly. I tried using the ball bearing with the YFZ pushrod but I couldn't get the clutch back together, the pushrod was too long.
Here are the parts, about $250 in total shipped but I believe you can get away with just the clutch. New YFZ slippers are floating around eBay for 200 bucks.
YFZ pushrod head on the left, WR on the right. There may have been a difference in diameter but I couldn't tell. Both sat against the clutch top correctly iirc, but I could be wrong in having used the WR piece.
Mid-install, YFZ clutch boss drops right in. 54 ft/lbs on the nut.
Clutch operates as it should and might have even made clutch pull lighter/ shifting smoother. Will report back on slipper function.
Edited by dirznut, September 23, 2016 - 10:14 AM.
