how tight do i get the valve cover bolts??????
7 replies to this topic
  • booda
Posted March 18, 2004 - 11:54 AM
i recently stripped out the small valve cover bolt hole i was able to rethread it using a tap. i then proceeded to tighten the bolt finger tight and then put a socket on it and got it snug. i hope it holds. any suggestions would be appreciated :) i love this bike
  • Throttlejockey
Posted March 18, 2004 - 11:57 AM
I'm sure it's fine. If you're that concerned you could Loctite it.
  • jcole24
Posted March 18, 2004 - 12:23 PM
I twisted off on of the long one's before I looked in the book, to find it only torque's to 7 foot-pounds. I always use loctite, that's not a very tight bolt. :)
  • CRF_mad
Posted March 18, 2004 - 05:49 PM
I just recently snapped 2 of them off on my bike, I couldn't figure It out, then I looked at the last bolt I had left and the threads were majorly stressed. I think honda made those bolts weak so you couldn't over tighten them, and break the seal between the cylinder head, and cylinder head cover. Because that gasket Is glued on the Cylinder head cover (valve cover) over tightening could break the glue bond. :) Locktite should work fine, But I don't think there's a prob with them coming loose, because they have rubber washers that keep them from vibrating, and then loosening. I'm just going to torque mine down to 7ft. lbs, and leave It. I think why mine snapped off was due to over tightening the first time I checked my valves, then the second time (now) they just couldn't take anymore. Thats just my Two Cents! :D
__________.:2004 CRF450:.__________
<ul type="square">[*]Fastway Accesories....Cable Clip, Case Saver, Clutch Bracket, F3 Footpegs,and Axle Blocks
[*]Works Connection Skid Plate, Engine Gaurds, Frame Gaurds, Brake Caliper Gaurd, Rad Braces, and Anodized Goodies
[*]ASV Rotator Clamp
[*]LightSpeed Carbon Fiber Fork Wraps
[*]Tach/Hour Meter
[*]Polished Side Cases
[*]Nology Hot-Wire
[*]Fuel Line Mod
[*]Zip-Ty Fuel Mixture Screw
[*]Factory R&D P-38 lighting
[*]AirBox Mod
[*]Back-Fire Screen Mod
[*]Twin-Air Air Filter
[*]D.I.D ERT Gold Chain
[*]Renthal 49T Sprocket
[*]13-49 Gearing[/list]------------------------------
Don't Hesitate Accelerate!!!! :D
____________________________________
  • HondaDirtRider5
Posted March 18, 2004 - 06:51 PM
remember its just a valve cover....so that means no pressure in there its just keeping dust out and the splashing oil in, not too tight i always use box end wreches to do the final tightening on bolts because i get less leverage and have a history of snapping bolts
also remember its rubber gasket and a bolt with a thick rubber washer so its not gonna bottom out or ever get very tight at al...with all that rubber compressing it should seal at a relativly low tourqe
  • CRF_mad
Posted March 18, 2004 - 07:02 PM
Exactly! :D
[*]Tach/Hour Meter
[*]Nology Hot-Wire
[*]Fuel Line Mod
[*]AirBox Mod
Don't Hesitate Accelerate!!!! :)
  • VerticalXtreme
Posted March 18, 2004 - 07:35 PM
I think the torque spec Honda uses is to HIGH on some of their bolts!!! There head bolts and valve covers are just two of them....
KTM is even worse....
I have a long history of very high level mechanics under my belt--- so I have learned to modify what they spec to what I think it should be... Especially on (not brand new) components........!!!!!
A torque wrench and paying attention to what your hands are feeling is #1....
I have rebuilt many CRF engines and have come to the same conclusion countless times. More or spec is not always better.
And loctite is great stuff, but there are places it does not belong... Ex: There is a valve cover bolt hole that functions as a oil gallery. ="s could be a expensive loctite job on that bolt !!!
Vert :)
  • CRF_mad
Posted March 19, 2004 - 05:32 AM
What Torque do you recommend. I'm really open to Ideas, and since you've been around them, you would know! :) Thanks!!!! :D
[*]Tach/Hour Meter
[*]Nology Hot-Wire
[*]Fuel Line Mod
[*]AirBox Mod
Low compression J & E piston 2014 CRF450R by stroker
Dirt Bike   Make / Model Specific   Honda   CRF450R/RX
  • Hot  29 replies
2008 CRF450r JB Weld on Crankcase by Sternzy
  • Hot  70 replies
2002 crf450r..Am I wasting my money rebuilding it? by Jonridesacrf
  • Hot  47 replies
2017 CRF450R :) by fraser
  • Hot  203 replies
02 crf450r smoking after rebuild by bigg_stevee
  • Hot  43 replies
