2009 shut down
2 replies to this topic
  • dougla12
Posted August 27, 2016 - 05:19 PM
Need some quick advice.
I was riding and the bike just shut down.
I tried to kick it but I wasn't getting that tight spot (compression slot)
So I pull the cover off and see the timing was off.
I set it correct. But now I'm looking at the cam lobes and realize they are at different angles.
Does this mean the cam is bad?
Also is there a way to see if any damage has been done to the valves without taking off the head? I remove the header pipe and the carb and tried to see to verify that a valve didn't drop.
Thanks
1472347130881.jpg 1472347135806.jpg 1472347144007.jpg 1472347153867.jpg 1472347168925.jpg 1472347183967.jpg 1472347191785.jpg
Edited by dougla12, August 27, 2016 - 05:46 PM.
  • dougla12
Posted August 28, 2016 - 05:06 AM
Update: I pull the head and all 3 intake valves are bend
Posted August 28, 2016 - 06:38 AM
It looks as if the intake cam sprocket has slipped on the shaft.  The two cams were never at exactly the same angle to begin with, but the intake lobe should be tilted up farther than that.  Plan on replacing the intake cam during the repairs.
