When did Yamah switch from a keyed ignition to a button?
22 replies to this topic
  • logansowner
Posted March 17, 2004 - 03:24 PM
I was at my Yamaha dealer today and I was checkin out all the bikes and I checked out an 04 wr250 and I noticed that instead of a key, the ignition was a grey button that is down for on and up for off.( I don't mean the E start)Is this something Yamaha switched to just this year? Because my friend has a 2003 wr250 and I'm positive he has a key :) I'd appreciate it is someone could enlighten me :D
  • dominator426
Posted March 17, 2004 - 04:05 PM
Your friend may have added an aftermarket ignition switch.
  • RichBaker
Posted March 17, 2004 - 04:47 PM
My 03WR450(US) has an on/off button as well as the kill switch....all stock.
  • Hamish
Posted March 18, 2004 - 01:03 AM
has anyone added a key switch, and if so which one. In Oz Wr's are registered. Cant even ride it to the shops without worrying if it'll b there when u get back
hamish
  • yamaha.dude
Posted March 18, 2004 - 01:27 AM
Hamish,
I put a kill switch on mine... plus I use a disc lock... but I still don't like taking it to the shops unless I can park it somewhere with a lot of people around... like at the main entrance or something... at least before the 450 cam mod I had a second level of defence... now, any dumb-ass criminal can jump on and get it fired up... I suppose I could always leave the bike with the choke pulled out... should make it a bit harder to steal...
I would like to have a combined ignition switch and steering lock... I had some ideas about such a thing a while back, when I first got the bike... I should start seriously thinking of the idea again...
David
  • logansowner
Posted March 18, 2004 - 02:59 AM
Well I feel like an idiot now :) I'm not sure if he did, I never paid that much attention but I thought I saw a key in there, but who knows.
So what is the point of having a button? If the ignition switch isn't a theft deterent, why have it in the first place? Wouldn't it be easier to leave it like the motocross bikes and have a kick start and e start but without the button?
  • Cmott426
Posted March 18, 2004 - 08:10 AM
So what is the point of having a button? ? If the ignition switch isn't a theft deterent, why have it in the first place? Wouldn't it be easier to leave it like the motocross bikes and have a kick start and e start but without the button?
You have to turn it off some how. Use the button instead of stalling it.
  • ddialogue
Posted March 18, 2004 - 09:08 AM
I'd be interested in finding that out as well. I'd love to add a key to mine and get rid of the button.
  • gomopar440
Posted March 18, 2004 - 10:34 AM
When I dual sported mine, I made a stainless steel box that was just big enough to hold one of those round key security locks and the LED thingy. I used the button bracket as a template for the mounting holes on the side and added a big and small hole on top for the switch and LED. The lock has a simple switch attached to the bottom which I wired the same way as the button. Works like a charm, doesn't rust and keeps the honest people honest :).
  • ddialogue
Posted March 18, 2004 - 10:38 AM
Photos?
  • logansowner
Posted March 18, 2004 - 12:21 PM
YEa, but you still have a normal kill switch don't you?
  • dominator426
Posted March 18, 2004 - 01:46 PM
The ignition switch was added to battery and electric starter equiped WR's. Kick-start models all had only a kill switch...
  • basicblues
Posted March 18, 2004 - 07:15 PM
I need this!! Post more details and photo's...
  • Hamish
Posted March 18, 2004 - 07:58 PM
I'm guesing that due to the fact the e-start model have a battery, they went to the kill switch to isolate the power when the bike is off. Whith the earlier 426's, the power is automatically off when the engine stops.
Hamish
  • gomopar440
Posted March 19, 2004 - 04:21 AM
I have some photos of the housing after it was finished and I'll try to get some pics of it installed on the bike. I'll need help loading them though, I've never done that before :). I started by making a cardboard mockup of the housing then transferred the pattern to some stainless steel sheetmetal, cut it, drilled it, bent it and welded it. BTW I had a friend do the (MIG/TIG?) welding on it (I'm a machinist not a welder :D). I made holes to fit for the switch, LED and mounting holes where it attaches to the upper tree and headlight housing. You have to remember to get a metric nut welded inside the box first so you will have some threads to attach the headlight housing. The LED inside the stock switch comes with a tiny circut board that I glued to the inside of the housing to keep the LED shining though it's hole. I tried to use some silicon to fill the bottom of the housing but the vapors corroded the switch so badly I had to cut it out and replace the switch. If you were to fill that area in the switch with an anti-oxidant grease that wouldn't happen. The idea behind using the silicon was to seal out any moisture from getting to the switch as well as make it so you could not see where the wires went to (and figure how to hotwire it). Like I said tho, it'll keep the honest people honest but anyone who can read an electrical diagram and isn't color blind could still get it if they wanted to.
PM me if you can post the pics for me and I'll send them this weekend :D
  • PBDBLUE
Posted March 19, 2004 - 05:05 AM
How about a small toggle switch in parallel with the kill switch hidden somewhere behind the headlight bucket. You can't defeat it if you can't find it. Still not bulletproof but at least you can make it difficult.
  • gomopar440
Posted March 26, 2004 - 03:16 AM
Ddialouge, will the pics I sent work? I haven't seen them here or on the www.WR450.com site yet :)?
  • RiverGirl114
Posted March 26, 2014 - 08:14 PM
I have an '09 Wr250 that I would love to add a keyed ignition for, but I don't want to spend $400 for a Baja kit when all I want is the key...
  • danpat1508
Posted November 30, 2015 - 08:42 PM
My 2003 has keyed ignition. I thought it was the norm here in Aus?
  • Krannie McKranface
Posted December 01, 2015 - 05:49 AM
11 year old thread  :rolleyes:
