03 wr450f clutch problem continued
6 replies to this topic
  • arlo7
Posted August 21, 2016 - 05:55 AM
I replaced the clutch cable and clutch plates and when put back together, as I put the bike into first the bike launches forward and stalls. I did not replace the clutch springs so idk if that could be my problem?
  • Pinepig
Posted August 21, 2016 - 02:47 PM
Did you coat all the clutch frictions in oil when you put it back together?
  • Krannie McKranface
Posted August 21, 2016 - 04:54 PM
Whose cable, whose plates did you use.
Did you replace fibers and steels.
Did you clean up the basket notches.
All WR clutches drag, espeically cold.
  • arlo7
Posted August 22, 2016 - 01:54 AM
Yes I did
  • arlo7
Posted August 22, 2016 - 02:00 AM
Cable was motion pro and plates tusk and I did replace fibers and steels. The basket notches didn't look bad so I didn't touch them. I let the bike run for a little bit and I still couldn't put the bike into gear without it stalling every time.
  • stevethe
Posted August 22, 2016 - 04:55 AM
Tusk plates are junk.
Posted August 22, 2016 - 05:39 AM
^ that
The Tusk plates and fibers are 'thicker' than stock, making your disengagement problem worse than before....
