  • Instagram
Related Reviews
Yamaha YZ450F 2010
Last review by flightrider
Yamaha YZ450F 2011
Last review by Le_Racer
Yamaha YZ450F 2012
Last review by Jason Heinrich
Yamaha YZ450F 2003
Last review by Garrett Canada
Yamaha YZ450F 2006
Last review by Yzrider1023
Related Garage
Yamaha YZ426F (2001)
Owner: phydeaux99
Added on December 05, 2016
Motor locked up
  • Please sign in to reply
35 replies to this topic
  • Braaap04
Posted August 25, 2016 - 04:11 PM
Okay. My bikes at my buddies house and I'll be back there tomorrow. Thanks I'll give that a try
  • Braaap04
Posted August 26, 2016 - 02:52 PM
I can turn it alittle big more with what you said to do greyracer513 but still locks up
  • Braaap04
Posted August 26, 2016 - 04:02 PM
I'm just an idiot. I didn't have the chain guide all the way in place causing that that that rotates down by the flywheel to hit it. Spins good once I fixed that issue
  • Braaap04
Posted September 13, 2016 - 11:49 AM
Okay back to the drawing board.. After putting it back together, put probably 20-25 hours on it. Not one issue, 1st or 2nd kick it was starting. Went to go for a ride yesterday and it was locked up again kicker wouldn't budge. I haven't checked timing yet since last time this happened timing was still dead nuts on. I pull the right side of the case of to check if any of those gears or spring was busted but everything looked brand new and nothing lodged in it. I thought the circlip I found was the problem but obviously not.. Anyone have any ideas..? Any help is appreciated as I'm getting real fed up with dirtbikes.. This thing is head for the dumpster pretty dang quick.
  • Ride_Flip_Repeat
Posted September 13, 2016 - 12:17 PM
My friends 98 yz 125s kick start gear was somehow connecting with the clutch basket gear and would be locking up the bike. Have you checked the kicker mechanism yet? Have you split the cases yet or just been digging around in the top end?
Posted September 13, 2016 - 12:18 PM
Well, since I don't see where you replaced the chain, I'd check the timing again.  Another possibility is a worn rod bearing in the crank assembly.
  • Braaap04
Posted September 13, 2016 - 01:10 PM
Ive dug around in the top end. I took that right side case off thats right behind the clutch and visually inspected the gears and did not find anything broke.
  • Braaap04
Posted September 13, 2016 - 01:15 PM
Okay I will check the timing on it again. How can I verify a worn rod bearing? If the rod has any slop in it? And without pull the cylinder off again, is their really any other way to check?
Posted September 14, 2016 - 11:39 AM
From the manual (measurement F):
  • Braaap04
Posted September 14, 2016 - 11:48 AM
Thanks for the help guys. Decided I'm not dealing with this anymore this summer. Someone should buy this bike from me lol
  • jmd426
Posted September 14, 2016 - 01:52 PM
How may dollar bills will it take to buy?
Posted September 14, 2016 - 03:03 PM
No selling/trading in the forums, guys.  You know the rules.
Use a PM.
  • Braaap04
Posted September 15, 2016 - 05:36 AM
Use a PM.
Sorry have not been on here long. Did not know that was a rule.
  • Braaap04
Posted September 18, 2016 - 11:34 AM
IMAG0091.jpg cam chain tensioner is still in. You can see how it doesn't sit properly in the gears, and where the chain feeds down in the case, is super tight. What my problem??
Posted September 19, 2016 - 07:02 AM
That might be the worst stretched cam chain I've ever looked at.  Replace the chain.
  • Braaap04
Posted September 30, 2016 - 01:02 PM
Sorry for such a late reply. I dont get on here much.. But I did. I ordered a new chain and tensioner since both are fairly cheap. I am hoping I do not have any bent valves. Hoping to get to fixing it one of these days!
  • 0 reviews
Motocross
  • Hot  491 replies
  • Hot  94 replies
  • 5 replies
