Just Purchased A YZ450FX! Need advice with build list
44 replies to this topic
Posted August 21, 2016 - 03:36 PM
#21
No compressor.  It comes off the bottom of the shock.  Slide the bumper up some, you'll see how it works.
  • XJHammer
Posted August 21, 2016 - 05:51 PM
#22
Yea I waited too. Then boiled over 4 times on one really nasty1st gear trail.
At speed I wouldn't worry about it.
  • NorCal
Posted August 22, 2016 - 06:58 AM
#23
What are your thoughts on a 1.6 radiator cap?
Posted August 22, 2016 - 07:10 AM
#24
That's 23.5 psi, and it's a bit high for my tastes, although it will effectively raise the boiling point another 10-15 degrees (F).  The risk it adds is that of a hose blowing or such as that.
  • jmd426
Posted August 22, 2016 - 01:55 PM
#25
Just say no. Use evans coolant and no worry's about cap pressure
  • Wiz636
Posted August 22, 2016 - 03:26 PM
#26
I wouldn't worry about the 1.6 cap, fan (unless you ride a lot of really tight, gnarly, 1st gear clutching stuff) or Evans coolant.
Make your own coolant.  Mix up a batch of 80% water, 20% ethyl glycol antifreeze, and few capfuls of a surfactant like Redline Water Wetter.
  • stevethe
Posted August 22, 2016 - 03:44 PM
#27
80% water likely means two things. A boil over and not enough corrosion protection.
  • Wiz636
Posted August 22, 2016 - 03:50 PM
#28
No, it sure doesn't. I've been running this mixture for 10+ years, over a thousand hours on four different bikes with zero issues.
  • stevethe
Posted August 22, 2016 - 03:55 PM
#29
What is the ratio of your mix in comparison to regular water and anti freeze.
  • Wiz636
Posted August 22, 2016 - 04:03 PM
#30
I mix 80% water, 20% ethyl glycol
  • stevethe
Posted August 22, 2016 - 04:23 PM
#31
All I know is in our type of extreme riding 50/50 coolant boils out pretty quick.
  • YHGEORGE
Posted August 22, 2016 - 05:12 PM
#32
"Coolant" is a misnomer. Water cools much better than anti-freeze. Only use as much AF as needed for temps and lubricating purposes.
  • stevethe
Posted August 22, 2016 - 05:30 PM
#33
Your right but water boils out immediately on our rides. All our riders without fans run 100% anti freeze. The ones that are new that don't are on the side of the trail boiled over with their bike overheating. On my 16' with a fan I run about 70/30 coolant to water. The other reason to run at least 50/50 is corrosion protection.
Much of what you run depends on what type of riding you do. There are lots of flowing trail riders out there that might get away with almost no coolant. But I would still run 50/50.
  • Krannie McKranface
Posted August 22, 2016 - 06:06 PM
#34
^ please note that this man rides vertical single track with 7 min long wide-open uphills ^
   He has 'unrideable' trails and hills named after him, and is known as 'the snake' in certain circles.
   There is no overheating and high-load senario that he has not experienced....and probably has discovered new ones in fact....
  • stevethe
Posted August 22, 2016 - 06:11 PM
#35
I feel like I just got busted.
  • NorCal
Posted August 23, 2016 - 01:00 PM
#36
Sounds like my kind of ridin' buddy!
  • Wiz636
Posted August 23, 2016 - 01:54 PM
#37
I'm confused. You mention 100% anti-freeze, 70/30 coolant to water, and then 50/50.
  • stevethe
Posted August 23, 2016 - 02:43 PM
#38
Yup different bikes and different riding. Not to be confused I called coolant as in = anti freeze.
Edited by stevethe, August 23, 2016 - 03:23 PM.
  • YHGEORGE
Posted August 23, 2016 - 05:02 PM
#39
My suggestion is to buy the Honda prepared product and forget about it.
  • stevethe
Posted August 23, 2016 - 05:37 PM
#40
Honda anti freeze is just a 50/50 mix.
  • Hot  113 replies
  • Hot  50 replies
