Non-ferrous chunks in bottom of case
6 replies to this topic
  • NorthernMNSurf
Posted August 11, 2016 - 08:49 PM
In the middle of a top and bottom end rebuild, and found these chunks in the bottom of the right side case, next to and embedded in the oil strainer.. Anyone have any idea on what this might have been? What would you check next before finishing the rebuild? I'm sweating this at the moment; I expected small shavings, not huge chunks that have clearly one through the gears...ImageUploadedByThumper Talk1470977234.115269.jpg ImageUploadedByThumper Talk1470977253.889517.jpg ImageUploadedByThumper Talk1470977265.593144.jpg ImageUploadedByThumper Talk1470977279.451803.jpg ImageUploadedByThumper Talk1470977293.973394.jpg ImageUploadedByThumper Talk1470977337.075946.jpg
  • Krannie McKranface
Posted August 11, 2016 - 09:21 PM
In the middle of a top and bottom end rebuild, and found these chunks in the bottom of the right side case, next to and embedded in the oil strainer.. Anyone have any idea on what this might have been? What would you check next before finishing the rebuild? I'm sweating this at the moment; I expected small shavings, not huge chunks that have clearly one through the gears...attachicon.gifImageUploadedByThumper Talk1470977234.115269.jpgattachicon.gifImageUploadedByThumper Talk1470977253.889517.jpgattachicon.gifImageUploadedByThumper Talk1470977265.593144.jpgattachicon.gifImageUploadedByThumper Talk1470977279.451803.jpgattachicon.gifImageUploadedByThumper Talk1470977293.973394.jpgattachicon.gifImageUploadedByThumper Talk1470977337.075946.jpg
Looks like a bearing outer that disenegrated...but you said it was non ferrous ?
  • NorthernMNSurf
Posted August 11, 2016 - 10:56 PM
Yes, correct: non magnetic. I inspected both halves too, nothing noticeable yet.
Posted August 12, 2016 - 06:21 AM
We talked about this.  Only some of that is non-ferrous.  Take it apart the rest of the way so you can find out what's what.
http://www.thumperta...2#entry13267158
  • cpetz24
Posted August 12, 2016 - 09:51 AM
Should be pretty obvious when the cases are apart.  Looks like some of the chunks went through the transmission.  Could it be part of the piston skirt, or maybe a chunk of the engine cases?
  • NorthernMNSurf
Posted August 12, 2016 - 10:49 AM
Ok, thank you for the replies. I have a new strainer on the way. I will pull apart the oil pump next and check for any missing aluminum parts. Gray, you mentioned flushing the frame reservoir would be difficult... I have the filter and pipe out already, should I just keep pouring oil down the dipstick opening until it's clear? Is there some sort of pump I could use?
  • NorthernMNSurf
Posted August 12, 2016 - 10:52 AM
I thought it would be obvious too; I don't see anything missing from the cases, piston is in tact (but shot)... The woodruff key (ferrous, thanks for the correction grayracer) makes sense but the aluminum chunks have me scratching my head...
  • 9 replies
  • Hot  113 replies
  • On January 15, 2017
