Baja Designs: WR Dual Sport Kits and XL Pro Headlight Replacement Kit
2 replies to this topic
  • Baja Designs
Posted August 11, 2016 - 12:00 PM
Bailey here with Baja Designs!  We have some great Dual Sport Kits and XL PRO headlight replacements available for the WR450F.
- WR450F, Dual Sport Kit, 2003-2006 (NO Headlight Kit)
http://www.bajadesig...o-headlight.asp
This kit was designed to utilize the factory headlight.
- WR450F, Dual Sport Kit, 2007-2011 (NO Headlight Kit)
http://www.bajadesig...r450f-07-11.asp
- WR450F, Dual Sport Kit, 2012-2016 (NO Headlight Kit)
http://www.bajadesig...r450f-12-16.asp
Includes:
  • Key Switch
  • Compact Handlebar Switch
  • Taillight Assembly w/License Plate Mount
  • Turn Signals
  • Hi/Low Turn Signal, Horn Assembly
  • Hydraulic & Mechanical Brake Switches
  • Wiring Harness
  • Hardware
  • Detailed Installation Instructions
We also have the option for a WR450F (2012-2016) XL PRO Headlight Replacement Kit!  This will replace your factory headlight and provide at least 3-5x more usable light!
The XL Pro puts out 4,900 Lumens and has a built-in dimming feature allowing a more "street friendly" low beam.
http://www.bajadesig...f-2012-2015.asp
Don't forget to call for your forum discount!
Thank You,
Bailey, Baja Designs
bailey@bajadesigns.com
1(800)422-5292x114
Edited by Baja Designs, August 11, 2016 - 12:17 PM.
  • RR@ARS
Posted August 11, 2016 - 12:28 PM
Just an FYI for all interested in the BD kit for a 2016-Newer
In order to keep your battery from being drained, you must keep the factory kill switch installed.  Removing the factory kill switch on a 2016 or newer will cause a drain on the battery even with the Baja Designs key switch plugged in with the key off.  So the key switch ends up only working to turn the light kit on and off and DOES NOT prevent the bike from being started whatsoever.
BTW this was not the case with my 2013 WR450F and the instructions that come with the kit do not address this issue.  Not sure if Baja Designs is really aware of this or not even though I made them aware of it.
Those of you with 2016-newer bikes may realize that the kill switch is not the same as the 2015-older models and has functions such as killing the motor only while leaving the electrics on for 60 sec upon pressing it once.  Holding the kill switch down for 2 sec will then shut off all electrics.  Again this was not the case with the 2015-older models.
Just trying to prevent someone else from having a surprise dead battery.
Other than that, the kit is good.  Typical Baja Designs quality.
Edited by RR@ARS, August 11, 2016 - 12:28 PM.
  • MXJunky
Posted August 12, 2016 - 07:28 AM
Bailey, thanks for the excellent customer service on hooking MXJunky up with a kit for his '15 WR450.  The installation went flawlessly and MXJ's blue sickle is now ready for licensing!
