Crank seal?
I replaced the rings on the piston and Hobbes the cylinder as well :/ I wiped some oil on the cylinder to help install.
I checked my coolant and its full.
I filled it with oil and haven't ran long enough to see if it's losing a lot. Should I just take it for a ride for a hour and see if I lose abunch?
Oil will enter the combustion camber threw piston rings or valve seals or worn guides. Your Deffinatlety burning oil.
Did you measure your piston to cylinder clearance or cylinder for being out of round?
Unfortunately you need to dive into it again.
I wouldn't ride it until the problem is resolved, the spark plug could foul at the worst possible time.
