Crf450rx 2017
Dang it Jetfuel got the holeshot on me.   Yo man,  that vid deserved its own thread  :cheers:
Curb weight 261. 450X curb weight 269. RX fuel tank 2.2 vs 1.9 on the X. If my math is right it weights 6 lbs less than the old X.
It weighs exactly the same as a 500EXC....which holds more gas and has EPA/DOT crap.
It's 15.9lbs heavier than a 450XC-F.
....but it will last 500 hours, not 200, and it will survive a high-speed get-off, and has real suspension.  All worth the 'weight'.
  • Like 3
Mmmm ok
Engine/Drivetrain
  • Smoother ignition map than CRF450R for better performance in low-traction situations.
  • Downdraft intake layout increases power by reducing resistance, improving air-charging efficiency.
  • Combustion chamber with high compression ratio, narrow valve angle for efficiency.
  • Use of finger rocker arm allows high valve lift while retaining compact Unicam layout.
  • Coils on valve springs have oval cross-sections to allow low engine height.
  • Port layout with straight flow for efficiency.
  • Diamond-like carbon (DLC) on piston pin, rocker arm minimizes friction, increases durability.
  • Dual muffler with gradual pipe bends for smooth exhaust flow.
  • Standard electric start, with kick start as a backup.
So is it the same engine as the R just with a different map? Guessing it doesnt come with selectable maps.
Theres a button on the left side that can switch between 3 maps.
Same as today's 2015-2016 R bikes. There's a "stock" map and 2 others pre-programmed (usually a "soft" and a "race) that can be re-programmed to whatever you like. Assuming the camshaft is the same, my bet is the stock map on the RX is slightly less aggressive than the R map, with fueling and ignition changes. Right-side button. Left-side button is Kill-MIL switch. Edited by Eddie8v
