I bought me a pair of Ohlins...now what?
9 replies to this topic
  • MN_Kevin
Posted March 16, 2004 - 06:07 PM
I paid $550 for some Cannondale Ohlins, complete w/ ENTIRE front wheel assembly (tube, NO tire), brake caliper and triple clamps.
I did pre-screen this purchase w/ a talk w/ the owner of Factory Connection here in NH. He did say the Ohlins were popular w/ Vets due to the more supple ride off the top. He said a couple of his Tech's are using them on their CR/CRF's.
He told me $550 was an absolute steel for these forks. And contrary to some guys knowledge, these Cannondale Ohlins are NOT K-Mart Ohlins.
They will need to be re-valved.
The GOLD color just gives me a hard on...I am going to the...uhhhh...bathroom for a couple of minutes (with my Sears catalog and one fork leg)! :)
  • Indy_WR450
Posted March 17, 2004 - 01:10 AM
Ohlins are very good. Problem with Cannondale designed units is the fit, springs, valving and brake caliper mounting makes it a pain for converting it on the WR450. But they are cool. :)
  • MN_Kevin
Posted March 17, 2004 - 02:31 AM
Indy, will it be an issue when I have the ENTIRE FRONT END off this C-Dale?
I did talk to a fellow TT'er (YZF450 guy) who said the only issue was the triple clamps...???
These forks will NEVER LEAVE ME! They will go from bike to bike.
I kinda fancy getting the internals anadized at Factory Connection. I AM friends w/ the owners brother... :) but I am aware of the Retail Business and giving deals. Once one guy gets a deal, EVERYONE WANTS A DEAL! :D
  • endurodog
Posted March 17, 2004 - 02:47 AM
Congrats on getting the deal!!! Hope to hear a ride report when you get them on.
  • Dan_Lorenze
Posted March 17, 2004 - 02:59 AM
Kevin, Wow.. You got a great deal... Even if you end up hating them you could always sell them for more money..
Dan
  • Eddie Sisneros
Posted March 17, 2004 - 05:00 AM
so they have the ti nitride coated tubes?
  • Indy_WR450
Posted March 17, 2004 - 11:49 AM
NH Kevin, You will need a custom triple clamps to fit them on your bike if they are not 46 mm forks. Other than that you can use the entire front end but you need a brake caliper, axle mount and maybe spacers for the wheel. Hub rotor postion may not match the caliper postion. This can be a comedy of errors. Be careful. :)
  • MN_Kevin
Posted March 17, 2004 - 12:02 PM
this is what I have (for $550.00)
1 - both forks
2 - entire triple clamp assembly (upper & lower triple clamps and stem)
3 - entire front wheel (including axle, spacers, rim, spokes, rotor, hub, tube, NO [rubber] tire)
4 - entire front brake assembly (lever, master cylinder, steel braided line, front caliper)
  • Indy_WR450
Posted March 17, 2004 - 12:07 PM
Then the only thing you need to make it fit is the stem needs to be pressed out and a yamaha size stem needs to be fitted. I am assuming the steering heads are different from manufacturers. As long as the stem and nut and steering head bearings will fit then you are good to go. :)
  • Alabama_Rider
Posted March 18, 2004 - 08:53 PM
Dan,
You sold your 03, WR450F for a KTM. Any comments??? :)
