  • Instagram
2012 WR450 High RPM Backfire and Stall
  • Please sign in to reply
22 replies to this topic
  • comp123
Posted August 04, 2016 - 11:14 AM
Okay, here goes again.  Since my motor rebuild last season, the bike has been running awesome. Now when I accelerate hard the bike backfires and in most cases stalls, in the higher RPMs. The bike starts right back up and will Idle and run fine as long as I don't hit the high RPMs. So, took off the FMF pipe and programmable ECU. Put the stock pipe and ECU back on. Pulled Fuel injector, pressure cleaned with solvent and replaced. Cleaned air filter. Checked AIRBOX and coupler to throttle body. Checked all vacuum lines and electrical. 12volt system, charging and otherwise, good. Changed Spark plug. TPS reads exactly5k. Changed oil.                                                  Went for a ride, got through all 5 gears full throttle several times. Gave it one last wide open throttle and backfire, sputter and stall. Start right back up pulled into the garage and here I am....
  • Krannie McKranface
Posted August 04, 2016 - 11:41 AM
Inspect your stator for metal debris sticking to the pick up
Also inspect your plug cap for a cracked solder, and the harness coming off the stator for corrosion.
  • comp123
Posted August 04, 2016 - 01:32 PM
The cap is good no cracks.Connections to the stator are good. The stator pickup is also clean of debris.
Posted August 04, 2016 - 02:50 PM
Did you open up the cap and look inside??
It has to be a momentary loss of spark or combustion, not jetting.
I would do a stator test.
  • comp123
Posted August 04, 2016 - 03:05 PM
Are we talking about the cap to the spark plug?
Posted August 04, 2016 - 03:14 PM
yes
  • comp123
Posted August 05, 2016 - 12:24 PM
Replace the coil and cap still no change.
  • comp123
Posted August 08, 2016 - 12:34 PM
Anyone else? So far I have changed the fuel. Spark plug. Pressure clean the fuel injector with solvent. New coil. New spark plug cap. New air filter. Checked all connections to and from the air box. Put back the stock ECU with the stock exhaust pipe. Checked all wiring and connectors.
Posted August 08, 2016 - 01:25 PM
Hmmmm, that's a tough one.
Have you checked your fuel pump filter, or it's maximum pressure over 2 minutes?
  • comp123
Posted August 08, 2016 - 03:18 PM
I removed the fuel pump from the gas tank. Everything looks brand-new inside. I have not done a two-minute fuel pressure check yet. I will look into the procedure and get it done.
  • comp123
Posted August 11, 2016 - 05:26 PM
Fuel pressure stays at 50psi when running. Is there anything I could look for if I take apart the throttle body? Running out of ideas... :banghead:
Posted August 11, 2016 - 06:30 PM
Is it possible you are hitting the rev limiter ?
  • comp123
Posted August 13, 2016 - 04:04 PM
http://www.dirtbikew...ad.php?t=113719   Valves???? Not the Rev limiter. Have not taken apart the throttle body yet. Going to have someone more competent then my self, check the valves.
Posted August 13, 2016 - 04:13 PM
Wait, I just read your original post again
You have not cleaned the pump filter ??
  • comp123
Posted August 13, 2016 - 05:01 PM
 Where is the pump filter? I saw a screen and it was clean. I did not disassemble the fuel pump, I just removed it from the tank and inspected it.
  • comp123
Posted August 13, 2016 - 07:02 PM
Took apart the fuel pump and inspected and cleaned a 1 1/2 by 2 1/2 inch screen attached to the fuel pump. There was zero contaminent.
  • comp123
Posted August 16, 2016 - 03:46 PM
Did a compression test came up with 50psi, Seemed low even with the decompression so I did a leakdown. test. Blew 100lbs into the cylinder at TDC. Got 70lbs out, with air escaping from the air filter housing. Going to pull the top end....
Posted August 17, 2016 - 08:40 AM
Bad intake valve..... :thumbsdn:
  • comp123
Posted August 17, 2016 - 05:35 PM
Not sure what's happening yet but this is what the top of the Piston looks like. Going to bring the top half to Yamaha tomorrow to see what they say.
  • comp123
Posted August 18, 2016 - 03:11 AM
More pics.
