Well take a look at this...wheel and axle issue
7 replies to this topic
  • djtroy
Posted August 03, 2016 - 06:27 PM
I recently purchased a set of wheels and after installing both wheels I had issues with the rear brakes loosing fluid and the front seals popping out. I took a look at the wheels and noticed that both axles are definitely too small for the diameter of the hub and bearings. Is there something I am missing here? The diameter of the wole is the same exact size as the fat end of the axle (pic included). Let me know if its just some sleeve I'm missing or if the wheel and bearings are just too big.
  • vossman23
Posted August 04, 2016 - 05:06 AM
Can't help you on the axle but the wheels look killer.
  • Monk
Posted August 04, 2016 - 05:11 AM
Look like you are missing the spacers. The spacers have a lip that sleeve down into the bearing...
Those look like SM Pro Wheels which I have a set
The idea behind the wheels is to use different spacers for for different axel sizes. You can use the same wheels for a YZ 250 as you can for a YZ450...
-The one has a 22mm ID that has a sleeve to go into the bearing (meant for a YZ250 2T.
-The one in the right has a 25mm ID but no sleeve because the bearing is the correct size for a 25mm axel.
As you can see they both fit. (I'm using my rear wheel as the example cause it's off the bike but it explains the point)
25mm
22mm
Edited by Monk, August 04, 2016 - 05:22 AM.
  • djtroy
Posted August 04, 2016 - 11:25 AM
Wooooowwwww ok thank you I have a bunch of different spacers.
  • djtroy
Posted August 04, 2016 - 11:28 AM
What diameter is the front axle. The rear is 22 mm I will try the spacers I have.
  • Monk
Posted August 04, 2016 - 11:31 AM
Depends on year***
14-17 22mm front, 25mm rear
09-13 25mm rear, 20mm front
99-08 20mm front, 22mm rear
  • djtroy
Posted August 04, 2016 - 11:54 AM
I don't have the proper spacers. I don't even have any that the front axle for through.
  • Monk
Posted August 04, 2016 - 11:59 AM
Call these guys, they should have the spacers...
http://www.ksrwheels.net/productcart/pc/viewCategories.asp?idCategory=497
  • Hot  30 replies
  • On January 15, 2017
  • 10 replies
