Ryco Moto rear plate bracket photo
12 replies to this topic
  • Krannie McKranface
Posted August 01, 2016 - 08:16 AM
Steve?
Bueller?
  • stevethe
Posted August 01, 2016 - 08:40 AM
Steve?
Bueller?
About like this one. However I also got a used one that was a tad longer. Both worked. http://www.thumperta...o-lighting-kit/
Edited by stevethe, August 01, 2016 - 08:40 AM.
  • finbike
Posted August 06, 2016 - 09:46 PM
Steve?
Bueller?
An other option is to make a plateholder yourself from an aluminium plate. The fender is quite thin and flimsy so it's better if the fastening points extend more to the front of the bike. That way the fender dont flap up and down as much. Even better would be to get an extention to where the aluminium backframe and fender is atatched together.
Edited by finbike, August 06, 2016 - 10:18 PM.
Posted August 07, 2016 - 06:33 AM
I have decided to make one out thick rubber-plastic.
Kind of like an old car tire carcass.
I found the material on line, but cannot figure out what it is called or where to get it.....yet.
  • Pinepig
Posted August 07, 2016 - 07:54 AM
I made one out of a tub for mixing sheetrock paste I picked up at Lowes for 6 bucks.
I just cut a big  piece out of the tub and then pulled the tail light cover.and cut a tab with a couple of notches in it to go around the two screw bosses to lock it in place.  The fit should be TIGHT if not oversized for the next step.
It's a weird shape in the pocket so I heated up my new part in the area that would sit in the pocket with a small torch ( till the plastic is shiny and floppy ). Quickly clamp it all together ( or screw it back on ) with the piece you made sandwiched between the lower cover and the tail light and wait for it to cool.  Adjust the angle of the plate holder by hand as it cools to get a angle you are happy with.  Use a rag soaked in cold water to shorten the process.
I left the " plate " part oversized and then trimmed it up once I mounted the plate to make sure it was straight.
First pic is the rough setup with the tub ( and it's missing piece ) on the floor to the left.
Second pic is mounted and done.
The material the tub is made out of is perfect for this,  just enough give to move ( hell you can fold it completely under the fender ) but it doesn't flop around while riding.
Edited by Pinepig, August 07, 2016 - 08:02 AM.
Posted August 07, 2016 - 10:12 AM
Yeah kinda like that
  • 2Speed
Posted August 16, 2016 - 06:52 AM
I just got my Ryco plate holder yesterday, It's way nicer than I anticipated. I'm just now getting around to plating my 2016 WR (busy summer) and this was a must have. After screwing around trying to fabricate something, I decided to bite the bullet and order this. It comes with all the correct hardware, nylocks, etc. Worth every penny of the $60!
Bracket:
Mock-up with turn signals. The holes are pre-drilled:
With included Delrin back plate:
  • vanxr
Posted August 16, 2016 - 08:12 AM
Bracket:
Yes they do LOOK good.  Unfortunately, the angle is wrong.  One time bottoming and the plate will catch the rear tire and tear it off.  Both my buddy and I bought one and both of us had the same issue.  The new WRs fenders are "floppier" than previous models.
  • stevethe
Posted August 16, 2016 - 08:28 AM
I haven't lost mine yet on my 16'. But I bolted it through with stainless button head bolts.
  • tomerb
Posted August 16, 2016 - 09:28 AM
My Delrin back plate broke and I lost my plate. Drill holes in your plate and bolt it to the aluminum bracket.
  • finbike
Posted August 16, 2016 - 09:51 AM
The 16 fender is definetly not designed to hold something more than its own weight. Flopps up and down like crazy when your driving behind in whooppie sections.
Posted August 16, 2016 - 09:53 AM
That's why I have decided against the Ryco bracket for off road, and am making one out of renforced rubber.
  • RockerYZWR
Posted August 18, 2016 - 05:02 AM
I made mine out of a piece of aluminum, might have been about $5 or so. It's held up great with mostly off road use, and with the integrated blinkers in the tail light ($15 on ebay), is definitely minimalist.
