450FX Idle Speed
5 replies to this topic
  • celler
Posted July 23, 2016 - 04:39 PM
I'll be getting a new 450FX and have read a lot about a good way to increase stalling resistance is to raise idle speed. Have done a lot of searching and cannot find a recommended RPM range. What have others found works well? I've been on 2 stokes for many years so I expect I will go though a learning curve.
  • stevethe
Posted July 23, 2016 - 05:08 PM
I believe the normal is above 2,000 rpm.
  • NW_drZ
Posted July 23, 2016 - 09:21 PM
I always run thumpers with a little higher idle. Just set it to what feels right, then forget it :)
  • stevethe
Posted July 24, 2016 - 04:29 PM
According to an expert I was told to set it at 2,000 and above or it can be easy to stall.
Probably says the idle speed in the shop manual.
  • Not sponsored
Posted July 26, 2016 - 03:20 PM
I turned it up two clicks and it seemed to help, also have a steel clutch basket which helped also (there has been some debate here about this but I noticed a difference). I also got the tuner and tried the hard pack map that someone else on here suggested, those 3 changes made it very difficult to stall.
  • celler
Posted July 27, 2016 - 08:06 PM
Thanks everyone. I have the power tuner and should have the bike in a few weeks.
