Oil cooler for 04 YZ450
4 replies to this topic
  • V8Astro
Posted July 16, 2016 - 10:56 PM
I've been lurking about trying to find ways of keeping my YZ cooler. I run a lithium battery for lighting. Getting a radiator fan complicates that.
I want to build my own oil cooler. I have access to hydraulic hose fab equipment. The only thing I'm not sure of is where do I get oil pressure from and where do I return the cooled oil?
  • Krannie McKranface
Posted July 17, 2016 - 06:48 AM
That motor holds plenty of oil, so  cooler won't drop the oil temp signifiganlty.
On the Honda's you only get 650cc of oil inside the motor, so an oil cooler increases capacity and keeps it cooler.
You could adapt the Quad YZF oil system parts to your YZ, with some effort....
https://www.google.c...chrome&ie=UTF-8
Posted July 17, 2016 - 07:18 AM
The problem in the first place is the cooling your oil won't really cool the engine significantly, just the oil, and there's no real evidence that the engine oil gets dangerously hot on most YZ450's.
What's your situation, what symptoms are you seeing?
  • V8Astro
Posted July 17, 2016 - 09:26 AM
No symptoms. I'm looking for another option to help keep the engine cooler
Posted July 17, 2016 - 07:13 PM
Well, it would be easy on the '04 ('98-'05 included) because of the external oil lines.  You would pick up the return oil line from the left side of the engine and install the cooler between the engine and frame in that line.  Be sure the cooler tubing is 5mm larger than the tubing that feeds into it so as to reduce the load on the pump.
Still, in the end, while the oil will be a little cooler, the engine won't really be any cooler for it to speak of.
  • Hot  113 replies
  • 9 replies
  • Hot  47 replies
