06 WR450 Valve shim limits
1 reply to this topic
  • WRfinatic
Posted July 16, 2016 - 07:34 PM
 On the older tappet valve motors I always set the intakes at the loose limit due to the valves sinking into the head over time, I also set the exhaust valves at the tight limit, they get looser from carbon buildup on the under-side of the valve.
Do the shim motors act the same way over time?
Has anyone had the exhaust valves on the wr get tight over time?
  • Krannie McKranface
Posted July 16, 2016 - 08:22 PM
Yes they do.
It happens, but not as often as an intake.
