What does the hot start lever do
4 replies to this topic
  • going up
Posted July 15, 2016 - 01:18 PM
I have heard several different things. I have a wr450. Can someone explain exactly what the hot start lever is doing and why you would use it.
  • Borgschulze
Posted July 15, 2016 - 03:39 PM
Leans the fuel mixture.
  • Krannie McKranface
Posted July 15, 2016 - 04:10 PM
The hot start is there to inject air into the intake and make it abruptly leaner, so a hot motor has less difficulty starting after stalling when hot.
When you motor is running, if you gently pull on the hot start, the rpms go up.
If when releasing the hot start the rpms stay up, that means you need to service the cable and the hot start plunger for lack of lubrication or corrosion.
It is also the primarly source for troublesome air leaks....
  • going up
Posted July 15, 2016 - 04:50 PM
Great explanation. Makes senes. Thanks
  • bobpara
Posted July 18, 2016 - 04:37 PM
Such a perfect explanation Krannie.....
