Sprocket info
4 replies to this topic
  • laroca1
Posted March 15, 2004 - 11:34 AM
I was going to change my gearing to 14-45. Any experience with Renthal, Sidewinder or JT Pro Series sprockets, my shop has the JT Pro Series brand. How does the 14-45 combo work. Thanks
  • irondude
Posted March 15, 2004 - 02:27 PM
sidewinder, ironman, or really any steel sprocket will do. Avoid aluminum unless you intend to change it all out agian in 1000 miles or so...45 is a good way to go.
Baja racers and some motarders will go with 15/45. Dakar racers will even pull 16/45!
  • ODSC1
Posted March 15, 2004 - 06:40 PM
Instead of changing the rear to a 45 keep the stock 48 tooth sprocket and go with a 15 tooth front sprocket. I'm sure the 15/48 gearing will be pretty close to the 14/45 that you want. The 15 tooth front sprocket can easily be changed back to the 14 tooth sprocket if needed.
Ontario Dual Sport Club
Posted March 15, 2004 - 10:11 PM
I use 14/45 for desert riding...need the top end, and 1st (with stock sprockets)useless in soft sand for going ANYWHERE!! Bike easily handles change! :)
  • laroca1
Posted March 17, 2004 - 09:32 AM
Thanks for replys. The reason I wanted to go with 45 rear sprocket is I wanted to lenthen my wheelbase to help with the added speed. I ended up with the JT brand I'll see how it works. I'll be in baja this weekend going to gonzaga bay from santa maria to try it out :cool:thanks gotta get ready :)
1993 XR600R rebuild by ove
  • Hot  41 replies
What was your path to Beta? by officialhopsof
Dirt Bike   Make / Model Specific   Beta
  • Hot  79 replies
  • Hot  35 replies
  • 7 replies
Can anyone identify this xr600 piston? by ms_mtn24
  • 4 replies
