Need 02-04 linkage measurements
No replies to this topic
  • R_Little
Posted March 15, 2004 - 05:16 AM
I have a 450 shock I's like to use on my 2000 WR.
It's 5mm longer and I believe the linkage is changed to compensate. I'd like to try the later model likage with the new shock. It needs to fit the older swingarm and frame.
Dimensions I need are:
Dia of the bolt that mounts the dogbone to the swingarm.
Width of the dogbone that fits into the swingarm including the bushings in the bearing.
Width of the pull rod where it attaches to the frame.
Dia of that bolt as well.
Thanks
