Bike Over Heating
10 replies to this topic
  • RowdeeT
Posted June 27, 2016 - 07:51 PM
I just bought an 06 yz450f with brand new top end, with hot cams and it's getting way hot when I ride. Would anyone know why?
  • Bigfoot0518
Posted June 27, 2016 - 08:28 PM
Is it boiling over or?
  • ThrustWasher
Posted June 27, 2016 - 09:58 PM
How do you know its getting too hot, What symptoms is it showing?
  • hawaiidirtrider
Posted June 28, 2016 - 12:24 AM
idk ..put some big radiators on it and a fan.
  • RowdeeT
Posted June 28, 2016 - 04:46 AM
It's coming out the over flow.
  • 0bigsilver6
Posted June 28, 2016 - 05:08 AM
Could just be over filled. If it's over filled it will boil out the over flow until it gets down to the proper level. Also maybe change the rad cap.
Posted June 28, 2016 - 06:55 AM
Is it heating while under way, or while idling for a while?
  • RowdeeT
Posted June 28, 2016 - 07:56 AM
While I'm riding. When I stop, I notice it.
Posted June 28, 2016 - 08:06 AM
Normal behavior would be that if filled to the top, the radiator will expel coolant as it expands until it reaches operating temperatures.  This should stop after it reaches this point, and it should leave the coolant about at the tops of the radiator tubes once it cools off.
If not, have a dealer test the cap.  It could be weak, and not holding adequate pressure.  If the cap's OK, whoever did the top may not have installed the head/head gasket correctly (torque).
  • kurtcrf450
Posted June 29, 2016 - 06:18 PM
Also they need airflow so if your not going fast enough it'll run hotter than normal because enough air isn't making it through the radiators to cool it
  • CDNSXV
Posted June 29, 2016 - 09:17 PM
As the top end was just done, I'd say the issue is a bad head gasket. Combustion gas is being pushed into the coolant system, causing the overflow, which then lowers the amount of coolant and causes overheating.
  • Hot  28 replies
  • On January 15, 2017
  • Hot  50 replies
  • Hot  30 replies
