2016 or 2017 WR450 vs YZ450FX?
16 replies to this topic
  • 24v
Posted June 27, 2016 - 10:20 AM
Hi everyone.  I am about to buy a bike to go to the desert.  I would like to do a combination of hard pack, and dunes.  I live in San Diego, so I have to deal with the whole Green and red sticker thing.
I know the WR gets a green, and the yzfx gets a red.  Red will limit my summer time riding.
With that said, is there enough difference between a wr and an fx to deal with the limitations of the fx due to the sticker, or is the wr close enough that I could mod it to be similar to an fx if necessary?
Sorry if this is a lame post or redundant question, I did try looking around and did not find an answer.  Any help is greatly appreciated.
  • stevethe
Posted June 27, 2016 - 11:14 AM
We've gone over it a couple of times. But a WR is pretty much the same bike. Suspension is supposed to be valved a bit different, springs are the same. The WR needs a rear section pipe and derestriction and you have the same bike with lights and a green sticker.
  • Krannie McKranface
Posted June 27, 2016 - 12:41 PM
The WR has more:
Restircted Muffler
Suspension valving softness
More wire harness
Front light
Rear light
Locked ECU
  • 24v
Posted June 27, 2016 - 03:17 PM
The WR has more:
Restircted Muffler
More wire harness
Front light
Rear light
Locked ECU
The wiring and lighting don't bother me as I would likely ad a bright headlight anyways.  The locked ecu and restricted exhaust bother me more as that is money I wouldn't need to spend on the fx.
  • stevethe
Posted June 27, 2016 - 03:57 PM
Let me see if I have that right. You spend close to $9,000 out the door on a bike and your worried about a used YZ rear section of the pipe and a $100. ECU. hum ok.
Posted June 27, 2016 - 04:47 PM
Yeah, I should have gone green sticker / WR, but the deals were not as good, and the idea of less 'stuff' on the bike appealled to me....even though I will probably add it all back anyway...
  • stevethe
Posted June 27, 2016 - 04:55 PM
Well your going the foreign plate route so you should be fine. But yea by the time your done you generally end up with a fx with lights or a WR with a fx pipe. So it kind of evens it out either way.
I still don't even know if the wr is a AC headlight or running off of dc.
Posted June 27, 2016 - 05:31 PM
Supposedly the FX has everything needed to add the lights; stator winds, harnesses, and inlcuding the rear light mounting bosses underneat thel rear fender...  but no harness plug for the trip computer.
  • stevethe
Posted June 27, 2016 - 05:39 PM
I think the headlight is running off of AC like the older carbed versions.
My WR headlight wires are in the front main harness. The only mod I did was to add a high beam switch and I used a pep boys pig tail that had the extra wire for the bulb socket.
  • stevethe
Posted June 27, 2016 - 05:47 PM
If you end up going DC on your headlight you may consider using one of the super bright LED bulbs that use very little power.
Posted June 28, 2016 - 01:58 AM
 My headlight may not even be funtional...
  • 24v
Posted June 28, 2016 - 02:52 AM
Is the ecu really only $100?  As for the rear section of the pipe, the head pipe does not have a catalyst in it?  I am just starting to learn, so that is why I am asking.
I truly appreciate the help.
BTW, I am also concerned about the softer suspension valving of the WR.  Is it much softer, or only slightly?  It really would be easier if we could test ride these bikes.  LOL
Edited by 24v, June 28, 2016 - 03:02 AM.
  • stevethe
Posted June 28, 2016 - 03:45 AM
No catalytic converter in the US. YZ tail pipes would be cheap on eBay. ECU is about $100. Suspension valving is slightly different but stiff on both bikes, same springs. Typically set up for a 180 lb. rider.
  • 24v
Posted June 28, 2016 - 03:53 AM
Hmm, I think you've talked me back over to the WR side of things. :)
  • Super_Davee
Posted June 28, 2016 - 04:55 AM
My YZ pipe was under $100 on eBay.
  • organicgun
Posted June 28, 2016 - 06:47 AM
In the wonderful state of california; I would consider that No matter how much money you throw at an fx it will never be a green sticker bike. But it wouldn't take alot to make the wr really good.
Edited by organicgun, June 28, 2016 - 07:05 AM.
  • stevethe
Posted June 28, 2016 - 07:02 AM
I would consider that; No matter how much money you throw at an fx it will never be a green sticker bike. But I don't think it'd take alot to make the wr really good.
Pretty much. If it was me and I was on a budget I would pick up a slip on or YZ muffler section and use a Pro Moto billet end cap. They have a spark arrestor built in.
