Front brakes not working properly
6 replies to this topic
  • cupcake2100
Posted June 26, 2016 - 12:05 PM
Hello i have a wr426 and recently my front brake started doing something weird. When i am stopped it works fine and when i pull the brake i will not move, however when i am moving and i pull the brake it will barley work at all, even pulled in enough to touch the handle bars, does anyone know what the problem is?
  • Chocos
Posted June 27, 2016 - 12:20 AM
Air contaminated, bleed it. If fluid is more than 3 years old it is recommended to drain it and use fresh brake fluid.
Posted June 27, 2016 - 09:56 AM
Doesn't sound that way.  I see no complaint of mushy feel or excess travel.  Sounds more like contaminated brake pads, and or a glazed rotor.
  • cupcake2100
Posted June 27, 2016 - 12:25 PM
Im not sure what the problem is, but today when i went for a ride the brakes were fixed! Cheers!
  • Krannie McKranface
Posted June 27, 2016 - 02:56 PM
Nothing fixes it self.
Do a brake system service, or you might get hurt
New fluid
Bleed it
Inspect pads and rotor for wear
If you have the original MC diaphram, you should replace it now....
  • cupcake2100
Posted June 27, 2016 - 05:43 PM
Sounds good, thanks
  • Chocos
Posted June 28, 2016 - 03:28 AM
Don't forget to put red rubber grease inside rubber boots. Do not put grease on pistons or inside the caliper. Only apply fresh brake fluid on new seal lips and cavities, piston bore. Silicon grease on caliper pin bolt shank.
Clean brake rotor contact surface with solvent prior to install.
Wear gloves when you deal with brake fluid.
