yz450f overflow problem
14 replies to this topic
  • Bigfoot0518
Posted June 25, 2016 - 08:21 AM
I put a new top end on my 04 yz450f and it wont stop leaking out the overflow. I tried a new radiator cap (didnt work) checked the oil for water no water. The only think i can figure is i didn't toque the head right and compressed gas is getting in the cooling passages.what do yins think?
  • Trailryder42
Posted June 25, 2016 - 08:31 AM
After having run the engine and the system cools off and you open the radiator cap, what is the level? Is it still slightly above the core or not?
  • Bigfoot0518
Posted June 25, 2016 - 08:39 AM
Its below the core after only a short ride.
  • Trailryder42
Posted June 25, 2016 - 12:04 PM
Is the new radiator cap the same temperature cap as the old cap?
And what temperature cap are you running?
Did you use new head / cylinder gaskets?
  • Bigfoot0518
Posted June 25, 2016 - 12:56 PM
The new radiator caps rated higher 1.6 and yeah all new gaskets
  • stevethe
Posted June 25, 2016 - 06:59 PM
First off are you using at least 50/50 to prevent boil over or more antifreeze.
  • Bigfoot0518
Posted June 25, 2016 - 07:25 PM
Yeah even tried engine ice
  • Krannie McKranface
Posted June 25, 2016 - 08:42 PM
And did you flush out all the water mixture per the engine ice instructions ?
Have you bleed the radiators for air?
  • Bigfoot0518
Posted June 26, 2016 - 04:13 AM
I flushed out the system when I put the engine ice in how would Ya get any air out of the system and would that really cause that problem
Posted June 26, 2016 - 06:47 AM
Air purges itself, so it's a non-issue.  If the system is filled at the radiator, that's all you need to worry about as relates to that.
My question is, how did you torque the the head?
  • Bigfoot0518
Posted June 26, 2016 - 07:26 AM
Didn't use a torque wrench to torque the head to spec so I figured that was the prob
  • motohead13
Posted June 26, 2016 - 09:18 AM
Torque to spec, criss-cross pattern
  • damnbiker94
Posted June 26, 2016 - 10:20 AM
Time for new head gasket and a torque wrench. Hopefully the head wasn't warped by whatever tightening method you used the first time.
Posted June 27, 2016 - 05:50 AM
Yes, and the torque procedure is more complicated than simply running them up to a number, too.
Read: http://www.thumperta...ead-tightening/
Torque pattern sequence is:
1) Left rear
2) Right front
3) Left front
4) Right rear
  • Bigfoot0518
Posted June 27, 2016 - 05:06 PM
I torqued it to spec runs great now .. Thanks for all yins help
