  • Instagram
Related Reviews
Yamaha YZ450FX 2016
Last review by gardwadt
Related Garage
Yamaha YZ450FX (2016)
Owner: gardwadt
Added on December 06, 2016
* * * * * 2 votes
The 'List'
Yamaha YZ450FX 2016
  • Please sign in to reply
170 replies to this topic
  • Krannie McKranface
Posted August 03, 2016 - 10:55 AM
Dammit, it keeps truncating my post!
Rest:
I am going to tip it over a lot, so durability is important. Don't care about cosmetic damage. (The XT has gone down at least 75 times since I bought it 2 months ago.)
I'd like to lower it a little bit, if that doesn't muck it up too badly. Sitting on the bike my toes barely touch, and I'd like a little bit more stability. But I *can* touch, so it's okay.
I weigh 192 and am losing weight, 5'10, if that matters to the discussion. Stumpy legs, long arms.
Single track here is a mix of:
woodsy tight turns with soft dirt & occasional tree falls and technical bits
highly exposed talc with loose shale (uuuuuuuuuugh)
some water crossings
Occasional quite steep bits
Lots of engine braking does not work for scary downhills. You loose rear wheel traction and can't regain it.
I almost always pull my clutch lever in on steep desents, using front and rear brakes.
It's about technique and saddle time...
  • TwentyFive20
Posted August 03, 2016 - 02:06 PM
I'm working on both!
  • TwentyFive20
Posted August 03, 2016 - 09:15 PM
Sorry for jacking your thread, BTW. I didn't realize there was a whole sub forum dedicated to "what bike should I buy".
To make up for it: here's the 3mm wrench I made today to adjust the valves on my XT.
  • MidlifeCrisisGuy
Posted August 03, 2016 - 09:22 PM
Did you try riding it without the steering stabilizer ?  Is it necessary for non desert riding ?
What made you chose 105mm of sag on it ?
What gear were you in when you stalled it on the climbs ?
Edited by MidlifeCrisisGuy, August 03, 2016 - 09:24 PM.
Posted August 04, 2016 - 06:19 AM
No. Yes, in all dirtbikes in rocky terrain.
Enzo racing recommendation.
2nd.
  • MidlifeCrisisGuy
Posted August 04, 2016 - 12:07 PM
I'm about to pull the pin on a YZ450FX.
How much better is it than your "custom" WR450 and the Beta ?  Are there conditions, like tight woods where the Beta is better than the FX ?
Is there anything about the FX that is turning you off ?  Is the off idle stalling curable ?
Edited by MidlifeCrisisGuy, August 04, 2016 - 12:08 PM.
Posted August 04, 2016 - 02:59 PM
The full-blown 2008 WR-to-YZ feels like a dinosaur compared to the FX.
It runs much better, less engine racket, better suspension, and much, much better build quality than any other Yamaha I have ever owned.
In everyway, the FX is better, accept two: the ergos are more compact, and the off idle torque is less.
Both can be fixed.
The BETA is better on the very tightest, steepest terrain......but it has a much more 'reserved' power delivery, even with a pipe and remap.
The BETA turns much tighter. The FX needs to have it's steering stops modified to be truley woods worthy (which I will do).
The BETA is very, very civlilized to ride. Smooth, compliant, flat power.
The Yamaha is more fun, but it tires you out when you use all that 'fun', and it's much less compliant in the ride. I don't mean the suspension, I mean the overall flex of the bike.
The Yamaha has more power everywhere, and the suspension is world class.  You can cross ruts at speed and it's no big deal. On the BETA or on a KTM you had better hold on tight...
It doesn't have an off idle stalling problem.
It has the same problem just about any modern FI bike has, and that is the power is kind of delivered in a 'crude' state. You have to fine tune it.
The Yamaha intake honk is annoying, as is the limited gas tank options.
There is an IMS 2.5gal tank coming that requires no modifications.
The intake honk can be lessended with some Dynamat and some earplugs.
  • TwentyFive20
Posted August 13, 2016 - 08:08 PM
Hey Krannie - I bought a 2016 WR450F today (DS conversion). I've taken it out for a short ride. It's freaking ridonculous. It's going to take some learning over my XT250.
What do you consider to be the absolute "must do" mods for this bike? Riding is mixed but there's always some woods and steep rocky talc single track every time I go out.
Posted August 13, 2016 - 08:28 PM
ECU change and mapping tool
Change out the stock exhaust tip, or muffler
Gearing
Ergonomics
Handguards
Quality tires and tubes
  • TwentyFive20
Posted August 13, 2016 - 09:08 PM
Gearing
Ergonomics
Handguards
Thanks man!
I've got the new ECU. The mapper is sitting in my Amazon cart while I add more stuff.
Exhaust tip - do you have a specific one? Can I just take out the restrictor and be done with it?
Gearing - shorter or taller?
Ergos - I may lower it (using a rear shock spacer and sliding the front forks up a bit). I have a Scott's on the way (with the risers).
Handguards - going on tomorrow.
Tires - I have Dunlop 606s on there now. Thinking about tubliss.
I might go with a Rekluse - it's tempting.
Going to add USB charging to the front, also fab up a custom dash plate (on my waterjet) to put that into along with the GPS & InReach
I don't seem to have the restrictor thingy that I thought some people have removed from their air box.
Would like a bigger tank that doesn't have saggy wings
Enduro Engineering bash plate is on the way.
Shoai battery is on the way.
Likely going to re-pad the seat with something shorter.
Edited by TwentyFive20, August 13, 2016 - 09:36 PM.
Posted August 13, 2016 - 10:54 PM
Don't lower it.
Just ride more and stop using your legs as outriggers.
Dunlop 606 tires are borderline dangerous on dirt.
Kenda makes several good DOT tires.
Don't waste you money on a Rekluse, unless you are racing, or have left hand issues.
You will be a much better rider if you learn to modulate the clutch at any rpm or load, not just the one that Rekluse gives you...
Practice locally on a small hill to get the clutch to just barely slip as you climb slowly. You will figure it out.
  • TwentyFive20
Posted August 14, 2016 - 05:06 PM
Don't lower it.
Thanks for the pointers and feedback!
After a good day of hard riding I've decided I'm not going to lower it and I'm not going to get a Rekluse. I am, however, going to get a softer seat.
I didn't find the Dunlops to be borderline dangerous. I was able to keep up (mostly) with the dudes I was riding with and I think that all of my dumps were self imposed. When I wear these out I'll look into the Kendas.
  • TwentyFive20
Posted August 14, 2016 - 05:13 PM
Oh yeah - what about the exhaust insert? Remove or replace?
Posted August 14, 2016 - 05:21 PM
Look at Seat Concepts and Guts Racing for seats.
I would just change the endcap with a PMB spark arrestor cap.
  • TwentyFive20
Posted August 15, 2016 - 08:05 AM
Those are nice looking endcaps!
I removed the pea shooter. I think I'm going to fab myself a fatter bored, shorter internal (the part that sits inside the spark trap) replacement.
Need to figure out if I want the soft or medium foam from Guts.
  • Bitteeinbit
Posted August 21, 2016 - 05:30 AM
Changes from 2015 to 2017 are pretty minor right? Big changes in 2007, and again 2015? I've seen a few 2015s going for cheap... Tempted.
Posted August 21, 2016 - 12:23 PM
FX is all new in 2016
WR is all new in 2016
WR was all new in 2012
You can get a '15 WR around here for $6500 otd...but the 1500 more is totally worth it.
  • Bitteeinbit
Posted August 21, 2016 - 04:33 PM
Really? The 15 looks exactly the same as the 16 and 17 (within on top, graphics etc). The 15 also has 6 gears, radiator fan and so on. Pretty sure it also has the rearward slanted engine. What differences are there between a 15 and 16 or 17 WR?
So from 12-15 is when they got the new look, along with fuel injection? FX would have been my first choice, but remapped and uncorked, seems like the WR is the ame as the FX. FX is a bit lighter though... Is $6500 for a 250 or 450?
Posted August 21, 2016 - 04:53 PM
No  year WR450F has 6 speeds, sorry.
2012-2015 is the 'regular' motor with FI.
2016 is the 'reverse head' motor.
The bikes share very little in common.
WR450F 2014/15 for $6550 otd all over the country.
This is the 450 forum, not 250.
  • TwentyFive20
Posted August 22, 2016 - 08:10 AM
Don't forget the new KYB suspension on the 16s as well. Yamaha is dumping remaining stock on the 15s because they have extras. I heard from my deal that there's at least a $1200 rebate on them.
16s are now becoming rarer as the 17s take over.
Yamaha YZ450FX 2016 by crash220
Yamaha YZ450FX 2016
  • 8 reviews
  • Last review by gardwadt
  • On December 06, 2016
2016 YZ450FX exhaust and mapping by Finchy637
  • Hot  34 replies
