'12-'15 WR450F Cooling Fan
13 replies to this topic
  • AtomicGeo
Posted June 19, 2016 - 07:37 AM
Can any of you help me with recommendations and experience installing a radiator cooling fan?  Maybe suggestions, pros/cons, and some pics?  Thanks.
Edited by AtomicGeo, June 19, 2016 - 08:01 AM.
  • Itsatruck
Posted June 19, 2016 - 04:31 PM
https://www.rockymou...oem-schematic/2
They have stock 2016 fans for $50.00 each. You can hard wire to a switch.
  • DRZ04
Posted June 20, 2016 - 09:32 PM
I put a Trail Tech fan on my '13 WR450f and it went on very easily and can be adjusted when  to come on & when to shut off. It also has a digital temp read out. It worked very well a couple of weeks ago up in the mountains. You may be able to do it cheaper on your own this is totally turn key.
  • AtomicGeo
Posted June 21, 2016 - 07:09 PM
Thanks for the help.  I am looking to buy one...my WR boiled over cause I ride too slow in rocky terrain.
  • Kidrman
Posted June 22, 2016 - 07:08 PM
I put one on and it stopped working. I suspect a bad connection and will troubleshoot this weekend, otherwise nice piece.
When it worked on initial install it cooled well.
  • Chaconne
Posted June 23, 2016 - 04:45 PM
http://www.thumperta...or-wr450/page-3
  • rwebb35
Posted June 23, 2016 - 06:15 PM
EVANS COOLANT
  • toten
Posted June 27, 2016 - 05:49 AM
EVANS COOLANT
Your bike can still seriously overheat with Evans. The coolant doesn't boil until 350ish I think, so you might not know your bike is overheating, but if you're running at 275 it is NOT good for the engine.
  • AtomicGeo
Posted June 27, 2016 - 05:54 AM
I use this stuff:
  • stevethe
Posted June 27, 2016 - 06:07 AM
You might be better off just running a slightly higher pressure cap. I run straight antifreeze in three of my four WR450's. Almost using straight in my 16'. Probably as good as running Evans without the hassle.
  • Kidrman
Posted June 27, 2016 - 06:01 PM
To follow up on my post above. Trail Tech is overnighting me a replacement fan. Great service with no hassles.
  • Chaconne
Posted June 28, 2016 - 02:29 PM
Trail Tech seems pretty good. The only thing I thought was lacking was the installation instructions. My Trail Tech fan has worked well for me otherwise.
Edited by Chaconne, June 28, 2016 - 02:29 PM.
  • jonrack
Posted June 30, 2016 - 07:30 PM
I have the trailtech fan and am happy with it so far. I agree that the instructions aren't great, though.
  • Chaconne
Posted July 01, 2016 - 01:27 PM
I added a posting in the link above with a trick at the end of the posted page. I used very small keyring 8mm wrench and I was able loosen/remove and tighten everything exactly the way needed to install the fan properly following the given instructions was causing damage to my radiator.
Jiggering things around in that area was just not working for me, removing all fasteners and re-tightening with the proper tools was the only way to go for me at least.
Edited by Chaconne, July 01, 2016 - 01:28 PM.
