What speed and gear does your WR powerwheelie on pavement?
35 replies to this topic
  • Agazza
Posted June 16, 2016 - 11:31 AM
No motards wheels, no jerking or snatching, just flooring the gas and up the front?
What mods have you done?
Im finding my WR a little sluggish
  • Nuklhed
Posted June 17, 2016 - 08:07 AM
3 rd gear.
  • Krannie McKranface
Posted June 17, 2016 - 11:10 AM
Wonder why no one is responding ?
  • woods-rider
Posted June 17, 2016 - 11:26 AM
gears 1-5, but why do you want to wheelie on pavement?
  • irme42day
Posted June 17, 2016 - 12:06 PM
Well living here in Arizona and being close to the Mexican border I just dump a bunch of Mexican Jumping Beans in the tank and let her rip.
Michael
G & H Acres
Beautiful Golden Valley AZ
Garden Spot of the Galaxy
Vacation Destination of the Universe
  • Agazza
Posted June 17, 2016 - 01:39 PM
I don't know? I suppose this is one of the bigger wr forums?
I did not want info from the motards because of the smaller wheel diameter
  • Agazza
Posted June 17, 2016 - 01:40 PM
3 rd gear.
What speed? Do you know the size of your sprockets?
How much do you weight?
Trying to do a power assessment of my bike
Posted June 17, 2016 - 01:55 PM
It's becuse your question requires a whole bunch more information, and even then, a slight lean one way or another would change the outcome....
  • Agazza
Posted June 17, 2016 - 02:11 PM
I know, but I do not think anyone here has acceleration times measured, but this will also suffice☺
It's just a estimate I'm looking for
  • Mr YumYums
Posted June 17, 2016 - 02:27 PM
I can easily wheelie in 3rd gear. I have irc gp-1s as tires. Just a slight tug in 4th I can go from 40mph to 60mph redlining doing a wheelie.
  • Borgschulze
Posted June 17, 2016 - 03:35 PM
The SuMo's are geared way higher, it's usually easier to wheelie a bike with the dirt wheels because it's usually geared for dirt riding.
Has almost nothing to do with the wheel diameter.
  • Mr YumYums
Posted June 17, 2016 - 04:06 PM
well actually, larger diameter tires give you more speed than smaller diameter tires. So smaller diameter tires can give more torque than larger ones. The diameter of a tire does matter.
  • toten
Posted June 17, 2016 - 04:30 PM
My 03 WR450 SM is geared (both tooth count and effective gearing, ie speed vs rpm) quite a bit taller than most WRs, at 14/40. It doesn't come up in 2nd without some effort.
The lower center of gravity also makes wheelies less likely.
  • Mr YumYums
Posted June 18, 2016 - 04:11 AM
how hard is it to get going from a stop? Do you really have to give it gas?
  • falconjet
Posted June 18, 2016 - 05:34 AM
I put helium in my front tire.
So I can wheelie at 100 in 6th gear.
This question is about as lame as the "What oil is best" question.
  • Borgschulze
Posted June 18, 2016 - 08:35 AM
I'm geared 15/41, top speed is over 100mph.
You can stall the bike if you're not careful taking off and let the clutch out too fast.
Yes wheel diameter can make it easier, but you're forgetting how much higher a SuMo is geared, it completely negates the fact that the wheel is smaller.
It's not as bad as my Husaberg 550 was though, that bike was geared 16/39, and it would easily stall taking off if you didn't slip the clutch enough.
For what it's worth, my SuMo will easily power wheelie in second, and if you time it right, third as well, but I suck at wheelies... I can get the front to come up a bit in 5th if I yank on it and dump the clutch.
Falcon is right though...
  • Agazza
Posted June 18, 2016 - 10:23 AM
Guys, give Me other ways to estimate my power and i will look at that instead, this purely for estimating if my bike is sluggish or not. People know how hard their bike is to wheelie, but none of you know your 0-60 time
Thank you everybody who tried to give me useful info
  • Nuklhed
Posted June 19, 2016 - 04:31 PM
It's 12 tooth up front, stock in the rear.  I weigh plenty, thank you very much.  I move my weight back over the rear tire, which helps.  I've also got a 3.2 gal tank.  The ECU is programmable and the snorkels are gone and exhaust tip is a GYTR.  I have to get it in mid-RPM as I tend to lug the engine.
  • chelder
Posted June 19, 2016 - 05:17 PM
74Kgs 14/51 GYTR/FMF full titanium system and tuned can pull a sic wheelie in 5th at 100kmph
  • Mr YumYums
Posted June 20, 2016 - 06:55 AM
I'll do a 0-60 time today. I will let you guys know. I'm sure it's under 4. Just need to keep the front wheel down
