99 YZ400 wont shift
No replies to this topic
  • Desmodus
Posted June 15, 2016 - 09:46 AM
I replaced the clutch cable on my YZ and I think I broke something. Or somethings. While replacing the cable I noticed the torsion spring on the push rod was kind of bent up so I took the clutch cover off, loosened the clutch springs and pulled the rod to replace the spring. Now when I put everything back together, it seems I'm not getting enough travel on the push rod. Or its not engaging soon enough, maybe?
Either way, it died when I shifted N->1st, and I can't get it to shift out of 1st. The clutch springs are all in spec (1.72") and torqued down. What should I be looking at to get a better/earlier engagement? Or could I have messed something up when removing the push rod?
Any help is appreciated!
  • Hot  36 replies
  • Hot  47 replies
  • Hot  30 replies
  • 0 replies
