Kickstarter Noise
Yamaha WR400F 1999
7 replies to this topic
  • JohnClaude
Posted June 12, 2016 - 03:39 PM
Hi Guys,
I've got some more noob questions for ya. My kickstarter is making a strange sound when I accelerate/rev the bike-it sounds like the kickstarter teeth and the shaft teeth aren't meshing possibly. It helps if I push down (clockwise) on the knurled horizontal part of the lever while revving the engine. I've attached some pictures, does anyone notice anything amiss? Thanks in advance for your help.
  • Krannie McKranface
Posted June 12, 2016 - 05:16 PM
The problem is inside
You should also fix the massive leak you have at the pipe junction..........
  • JohnClaude
Posted June 12, 2016 - 06:55 PM
Thanks for the reply, Krannie. You read my mind- my next question was going to be "how do I fix this massive leak that I have at the pipe junction"! Should I just remove and inspect the kick axle assembly and kick idle gear per the manual? Any suggestions on how to get rid of that pesky exhaust leak that I definitely didn't just notice?
Posted June 12, 2016 - 06:57 PM
It looks like you have a YZ slip-on muffler attached to the stock WR header, which is a different size, hench the 'spacer'.
No way to know what is wrong with the kickstarter until you open it up and look.
  • JohnClaude
Posted June 12, 2016 - 07:04 PM
The exhaust is a White Brothers E-Series that is obnoxiously loud...upon closer examination you're right there is a poorly made spacer there. Yikes. The wonders of 'previous owner' fixes never cease to amaze. I'll pull out the kickstarter mechanism in the next couple days and check everything out and report back. Thanks again Krannie.
  • JohnClaude
Posted June 25, 2016 - 12:32 PM
UPDATE: Well I figured out the source of my problem. The kickstart stopper had split, and in the process took out a chunk of the case. I replaced the stopper, but am unsure what to do about the case. I've attached some pictures below. Any suggestions/comments are welcome. I'm hoping to get by without doing anything, but I don't like the look of things. Let me know what you guys think.
  • toten
Posted June 27, 2016 - 05:48 AM
If it seems to still work with a new stopper, I wouldn't do anything to the case (other than flush oil/filter a few times thanks to all the crap that must be in it).
  • JohnClaude
Posted June 27, 2016 - 01:42 PM
Thanks for the response, toten. I was able to get most of the aluminum that broke off (it was caught behind the stopper, luckily). I'll definitely flush it a few times though. I put some JB Weld to build it back up slightly, more for peace of mind than anything.
1999 WR400F-Good Deal? by JohnClaude
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
  • 11 replies
Yamaha by Tobyperkins17
  • 10 replies
YZ/WR400 Camshaft Cap Interchangeable? by JohnClaude
  • 3 replies
Yamaha WR400F 1999 by ThumperTalk
Yamaha WR400F 1999
  • 16 reviews
  • Last review by SprytnySpawacz
  • On August 25, 2016
