Wr450f at higher speeds wobbles quite a bit
Yamaha WR450F
28 replies to this topic
  • Turtlerider
Posted June 11, 2016 - 04:06 PM
Is this normal and something that can be solved with something like a scotts steering stabilizer or is there possibly something wrong ? Its at speeds around 70mph or higher. Any input is appreciated.
  • stevethe
Posted June 11, 2016 - 04:48 PM
Check everything, bent rims, tires not seated properly on rims etc.
  • Krannie McKranface
Posted June 11, 2016 - 04:52 PM
Define 'wobble'....
Do you mean the handle bars wag left to right?
The wheels jump?
The rear fish tails?
  • ttreewalkerr
Posted June 11, 2016 - 06:54 PM
Front shocks choked up too far in clamps.
  • Turtlerider
Posted June 11, 2016 - 10:05 PM
Define 'wobble'....
The wheels jump?
Handle bars left to right
  • SatansReverence
Posted June 12, 2016 - 02:21 AM
Eh, I've done 162kph (100mph) on mine with no wobble. Probably got something wrong somewhere like a bearing or something.
  • Turtlerider
Posted June 12, 2016 - 04:34 AM
Oh dang. Completely stock, no stabilizer? And gearing do you have?
Posted June 12, 2016 - 04:48 AM
Rear wheel alignment
Rear sag/ fork height
Steering damper
  • Turtlerider
Posted June 12, 2016 - 08:49 AM
Steering damper
Those the things that could be off causing this?
And you think a steering damper would help this?
Edited by Turtlerider, June 12, 2016 - 08:50 AM.
Posted June 12, 2016 - 12:02 PM
Yes and yes
  • Turtlerider
Posted June 12, 2016 - 02:07 PM
Yes and yes
And when you say fork height, is the tripple clamp too high on the fork?
Posted June 12, 2016 - 02:34 PM
It's all inter-related
Forks slid up in the triple clamps will give less rake/faster turning / more head shake
Sag to small in the rear does the same thing
Handling is tuned by fork height and sag, but usually at the expense of some head shake and deflection
That is why steering dampers exist
If your rear wheel is not perfectly aligned then it too causes problems
Also, the WR450F is never going to be highly stable at 70+ mph, as it was not made for that.
You MUST balance your front and rear wheels before going that fast for any length of time.
You really need to get a manual on basic motorcycle set up as this is entry level stuff
The Yamaha factory service manual is very good, and free from Yamaha
  • Turtlerider
Posted June 12, 2016 - 03:16 PM
Ya, i already have one, just didnt realize asking for help on a forum was frowned upon.. If it hurts you too much to help, you dont have to. Im not forcing you, i promise.
Posted June 12, 2016 - 04:43 PM
No, but being a dick to someone who is helping you is frowned upon...
  • stevethe
Posted June 12, 2016 - 04:49 PM
Wow a greatfull guy that lost all of his greatness and ended up full-of-it.
  • SatansReverence
Posted June 12, 2016 - 08:24 PM
Was completely stock, gearing was 14/47 but I've since changed that.
  • Turtlerider
Posted June 13, 2016 - 10:45 AM
Gotcha, thanks
  • Turtlerider
Posted June 13, 2016 - 10:52 AM
Didnt realize how butt-hurt everyone gets.. Why the smart little comments then? So if you offer help, you can be a dick about it? That how it works here?
  • toten
Posted June 13, 2016 - 02:32 PM
The other day I had mine up around 95-100 and it seemed perfectly fine. Oddly enough, I've had a bit of a weave at 80ish before, not sure why it didn't this time.
17s with street tires and suspension isn't stock, but no damper.
  • stevethe
Posted June 13, 2016 - 02:55 PM
Hey check your personal issues prior to posting nonsense mate.
Edited by stevethe, June 13, 2016 - 02:57 PM.
