Rear bearing problem
5 replies to this topic
  • terry450
Posted June 11, 2016 - 01:35 AM
Ok my bike is a 2012 WR 450 I just replaced the rear tire bearings for the second time in less than a week and I keep getting this problem soon as I replace the Bearing and put the wheel back on tighten everything then give the wheel a little shake back and forth there's a little play so much u can hear the clicking its between the wheel spacer and the hub on the rim.. Any suggestions..........
  • xcbuckeyeguy
Posted June 11, 2016 - 05:15 AM
Are you sure the play is in the bearings and not the hub? Do you have to press the bearings in the hub or do they slide freely?
  • terry450
Posted June 11, 2016 - 12:21 PM
I need to press them in
  • xcbuckeyeguy
Posted June 11, 2016 - 02:17 PM
Check your axle for signs of wear. Are you using OEM bearings?
  • terry450
Posted June 11, 2016 - 09:04 PM
No I'm using all balls and another brand I forget what it was
I was looking at it again I can see a little gap between the wheel spacers and the hub? Did you ever hear of the wheel spacers wearing down ?
  • terry450
Posted June 16, 2016 - 07:18 AM
Any one?
