2017 WR450F
30 replies to this topic
  • stevethe
Posted June 20, 2016 - 05:55 PM
#21
Is there a larger aftermarket fuel tank available for the 2016-17 WR450F Yamaha?
http://www.thumperta...-on-a-fx-or-wr/
There is also the crappy looking IMS shroud tank made for the WR or FX and one more 2.5 gal tank that IMS makes for the FX with a quick fill. It can be converted to a regular cap. Do a goggle search.
Edited by stevethe, June 20, 2016 - 06:42 PM.
  • ktm300
Posted June 23, 2016 - 06:02 AM
#22
I did the demo ride at the national enduro last week, rode the WR450 and 450FX back to back, the WR had controllable power, excellent suspension and turned as good or better than my Beta's, the FX seemed the the suspension was a smidge firmer but the power was instant and considerably more than the WR.
I need to replace my 2014 Beta 450rr this fall and am leaning toward the 450FX, I to need power to run a head light and hand warmers in the winter, can the power on the FX be easily altered or is it stuck in YZ mode .
  • stevethe
Posted June 23, 2016 - 06:36 AM
#23
FX power is altered with the tuner. The fx has the same amount of electric power on tap as the wr. Both bikes also have the same amount of horse power given the wr is de restricted and a rear section pipe is put on.
  • ktm300
Posted June 23, 2016 - 08:49 AM
#24
How close is the FX map to the YZ map ?
  • stevethe
Posted June 23, 2016 - 10:22 AM
#25
Not even Yamaha knows or do they. You put the competition ECU in the WR and it's programmable just as is the FX.
  • sledhead999
Posted June 27, 2016 - 04:28 PM
#26
Does the WR and FX share the same cam profile? or does the FX use the YZ cam maybe?
  • stevethe
Posted June 27, 2016 - 04:48 PM
#27
For 16' it is said they all use the same cam profile. The difference in the YZ cam is its decompression pin is slightly different as it is kick start only.
  • Krannie McKranface
#28
YZ/FX/WR share the same exact head and cam and cylinder internals.
The YZ has a lighter crank, stiffer clutch, different map, stiffer damping, stiffer engine mounts, etc.
  • stevethe
Posted June 27, 2016 - 05:02 PM
#29
Ha exact same posting time. But the part number for the YZ exhaust cam will be different.
  • sledhead999
Posted June 28, 2016 - 08:01 AM
#30
Doesn't that usually mean its a different part? Hence they don't share the same exhaust cam?
  • stevethe
Posted June 28, 2016 - 10:44 AM
#31
Absolutely a different part. But it is supposed to be the same cam profile.
