I need help quick
20 replies to this topic
  • Hypheriox
Posted May 31, 2016 - 07:14 PM
I just did an oil change on my 03 wr450 about a week ago, the first one since I bought it.(not the original owner obviously) When I checked the oil then, it was just a bit over and smoking a bit so I drained out a bit. I checked my oil today and it said I had no oil. I have been putting oil into it but now its smoking alot like I am way over full but nothing is on the dip stick. what is wrong
  • schrode
Posted May 31, 2016 - 07:23 PM
sounds like you're not checking it correctly and consequently over-filling it. what does your manual say?
are you adding to the crank, running it, then checking it? what's the procedure you're following?
Edited by schrode, May 31, 2016 - 07:27 PM.
  • Hypheriox
Posted May 31, 2016 - 07:33 PM
Well since it has a steel frame, the manual says in order to check the oil level, let it run for about 3 minutes on a level surface and warm up, the shut it off and check the oil level. That is what I have been doing and it still says no oil
  • emperialwizzard
Posted May 31, 2016 - 07:38 PM
From my experience a frame should not have anything to do with oil or the level. Drain it all, fill it to the proper amount per the manual, and as long as it isn't leaking you are fine. Dirt bikes don't need dip sticks.... It's really not a "check and top off thing" you fill it with the proper amount. Run it for the allotted hours (per the manual), dump it and re-fill...
  • Hypheriox
Posted May 31, 2016 - 07:42 PM
This is an 03 wr450, the steel frame holds oil and distributes it to the tranny and engine via a two pump system
  • ass
Posted June 01, 2016 - 03:37 AM
Are you letting it sit a minute before checking it? You need to check warm but also give time for oil to settle back to level.
  • N1TRO
Posted June 01, 2016 - 04:36 AM
I'll tell you what I do per my manual for my 250f in the morning. Steel frame too.
  • emperialwizzard
Posted June 01, 2016 - 05:52 AM
O wow, that's kinda wild. I see what your taking about now, but it still should not change the amount of oil you would use.... Unless it would be somehow possible for the oil to be getting blocked somewhere, say between the reservoir and the motor or something? I'm not sure. Found this video for ya though...
https://m.youtube.co...h?v=H20ELzoVOs0
  • Krannie McKranface
Posted June 01, 2016 - 07:16 AM
Have you cleaned the frame screen?
Have you cleaned the lower pump filter passage from debris?
Have you checked the pump pressure using the test bolt?
You need to download a factory service manual from yamaha's site and follow the oil system maintenece intervals
  • emperialwizzard
Posted June 01, 2016 - 07:36 AM
[quote name="KRANNIE" post="13142075" timestamp="1464794205"]Have you cleaned the frame screen?
You need to download a factory service manual from yamaha's site and follow the oil system maintenece intervals[/quote
Knew here had to be some way for the oil to be trapped or blocked. Just never owned a bike with oil running through the frame. Any positives to this design? I'm curious as to why they designed it like this. Sounds like a pain!!!
  • toten
Posted June 01, 2016 - 11:30 AM
It allows extra oil capacity without increasing engine size, and also acts as an oil cooler. It's fairly common (XRs do it too).
  • Hypheriox
Posted June 01, 2016 - 11:31 AM
OK I just drained the oil and put 1 qt in. It is sitting exactly in between the full and low mark so I am just leaving it there
  • emperialwizzard
Posted June 01, 2016 - 11:33 AM
Huh, very interesting. Never owned a big trail bike, my 90 model XR80 doesn't do this either so never encountered that. Kinda cool though. Just sucks that it can obviously get clogged, etc.
  • Hypheriox
Posted June 01, 2016 - 11:34 AM
Another weird thing about them is they do not have a sight glass to check the oil you have an actual dipstick
  • emperialwizzard
Posted June 01, 2016 - 12:15 PM
That is kinda odd too. But actually none of the 4 bikes I own have either. No dipstick, or sight glass. That's why I am very anal about getting the proper amount in there and keeping it changed... ;). Needless to say, I have learned the hard way. Haha never run low on oil!!!
  • DeepPurplishBlue
Posted June 01, 2016 - 12:45 PM
If there is enough debris in your engine to clog that screen you probably have some bigger problems to sort out...
  • emperialwizzard
Posted June 01, 2016 - 01:36 PM
I would agree. That doesn't sound good at all. So what do you think the OP's problem is? Sounds like something is clogged to me, but that is only because he said he was putting oil in and it was not getting to the dipstick... I obviously know very little about this, but it is interesting. Man if all of the oil was clogged and couldn't reach the motor you would be EFFFED!! It sounds anyways...
  • Hypheriox
Posted June 01, 2016 - 05:12 PM
Okay I'm pretty sure I solve the issue all I did was drain all the oil by removing all 3 drain bolts and also replacing the oil filter because I needed to do that anyways and I added exactly one quart of oil and after properly checking it the oil is sitting right in between the full and low line on the dipstick so I think my issue was that I wasn't letting the bikes sit long enough before I was checking the oil
  • schrode
Posted June 01, 2016 - 11:32 PM
that'll do it. i have an xr400 that uses the same method and it can be fickle setting the level if you don't follow the right protocol. glad you worked it out.
  • Hypheriox
Posted June 02, 2016 - 05:49 AM
How is the xr400 I almost bought it instead of what I got now
