Camshaft Gear 2013 YZ450F problem
6 replies to this topic
  • piwtorak
Posted May 30, 2016 - 08:39 AM
HI folks,
due a problem of compression the gear of the camshaft has rounded in the axle...and now is out of original position,
how can I turn to the original position and how this is position ?
thanks in advance for this help....
  • Krannie McKranface
Posted May 30, 2016 - 09:04 AM
HI folks,
You need to redegree the cam
If it actually is slipping though, you have much bigger problems
  • piwtorak
Posted May 30, 2016 - 10:00 AM
Hi Krannie, Thanks ....
can you explain the redegree process ? I do not understand this expression....
  • highmarker
Posted May 30, 2016 - 10:07 AM
how exactly did you determine the sprocket slipped on the cam ?   you sure your at the correct TDC (there are 2)
  • William1
Posted May 30, 2016 - 10:13 AM
Degreeing a cam is not a job for a novice, even many 'pros' cannot do it. You need special tools and the ability to remove and reinstall the gear on the cam. Some big shops have a jig used to hold everything in alignment during the pressing process. Then they tack weld the gear to the shaft to keep it from moving again.
Google Cam Degreeing
http://www.webcamsha.../degreeing.html
  • highmarker
Posted May 30, 2016 - 11:38 AM
yep even hot cams screws em up sometimes
  • piwtorak
Posted May 30, 2016 - 02:31 PM
Thanks for the answers, I will take this decision and let you know the ends....
  • Hot  30 replies
  • 10 replies
  • Hot  28 replies
  • Hot  38 replies
  • Hot  47 replies
