Uncorking WR price?
4 replies to this topic
  • Ammity
Posted May 29, 2016 - 04:57 AM
Hey lads, I'm about to buy a dead stock 2008 WR. I was curious of the price (in Australia) that a mechanic would charge (ballpark figure will do) to totally derestrict it and tune the carb once I put the full gytr exhaust system on it?
  • Agazza
Posted May 30, 2016 - 12:14 AM
I never touched a bike before and I bought a JD jetting kit, some tools and tried doing everything myself with the help of the forum and YouTube. It's really easy, just be patient.
Doing it yourself gives you better knowledge of you own bike and why it behaves a certain way.
I would not pay for more then 3 hours of work, and that's being generous. A mechanic should be able to do it much faster.
  • Krannie McKranface
Posted May 30, 2016 - 02:09 PM
A JD jetting kit will get you 50% of the way there
You can't change just the main and pilot and needle and not get bog and slugging off throttle response.
You need to change over to YZ specs and upgrade the apump.
Main jet
Needle jet
Jet needle
Apump upgrade
ACV block off
Pilot air jet
R&D fuel screw
YZ header
YZ exhaust
About 6 hours x your local going rate + $150materials + exhuast price
  • Ammity
Posted May 30, 2016 - 09:09 PM
This better be worth it. I'll just tell the Mrs the only cost is the exhaust haha. Thanks lads
Posted May 30, 2016 - 09:19 PM
No way to tell if you think it's worth it.
I can't ride one without being properly set up any more.....but then I ride quite often.
