2014-2016 YZ450f Flywheel Weight Manufactures
14 replies to this topic
  • trailrydr9
Posted May 26, 2016 - 08:59 PM
After searching around in here I had been reading about how good the welded flywheel weight was from Debauch Racing. So I emailed them and asked if they are still doing flywheels, since they aren't advertised on their web page anymore.  Unfortunately they have discontinued them.  So my question is, are there any other manufactures besides Steahly, and the 4.4oz GYTR?  Not sure about the glued weight, and I would also like to be able to see the TDC marks.  It sounds like that is not possible with the Steahly weights.
  • Gaskill
Posted May 26, 2016 - 09:51 PM
I have a 16 450 and I ordered a Steahly, well I sent my wheel to them and they sent it back with the weight on it. So I get it back and putting it on and the weight was rubbing the case on the motor side. Needless to say sent it back, gave me money for weight and money for s new wheel. I bought the gytr and love what it has done to my bike.
Posted May 27, 2016 - 07:00 AM
Do not be fooled into thinking that the 4.4 ounces added to the GYT-R weight is too small to be effective.  Weight placement from the center has a lot to do with how effective the additional weight is, and because of the considerably larger diameter of the rotor for the EFI bikes, the 4.4 ounces adds more inertia mass to the EFI flywheel than 9 ounces does on the flywheel for the carbed bikes did.
  • xcbuckeyeguy
Posted May 27, 2016 - 10:31 AM
+1... I had a 9 oz on my 08' and currently have the 4.4 oz on my 14'. The 4.4 oz is every bit as effective.
  • trailrydr9
Posted May 27, 2016 - 10:46 AM
Thanks for the replies. I ride in some fun riding spots, but sometimes it includes switch backs going up hill. I think a little more rotating mass will help when I mess up the clutch timing. I just came off a KTM 380 that seemed to just grunt and XR's before that. I have some getting used to with this bike, but I can feel that I have made the right choice, just a matter of me catching up.
  • xcbuckeyeguy
Posted May 27, 2016 - 12:34 PM
The GYTR flywheel definitely helps the low RPM stalling. It makes it easier to lug in the slow sections too. Whack the throttle and you will never notice the extra weight of the flywheel.
  • Decreasing Dave
Posted May 28, 2016 - 03:23 PM
Will the GYTR flywheel off of an '06 fit the '16?
  • trailrydr9
Posted May 28, 2016 - 08:00 PM
I am not 100% sure, but I don't think so.
Posted May 29, 2016 - 06:19 AM
I'm 100% sure it won't.  They are not even close to the same.
  • JonL515
Posted May 29, 2016 - 04:06 PM
I put a Gytr on my 14 yz 450 and it helps, but will not eliminate flame outs if you are in the wrong gear coming into a corner. Better clutch skills or a rekluse will help with that. They accomplish the same as the steahly and are much easier to install and remove if necessary. Worth the extra money IMHO.
  • cowboyona426
Posted June 01, 2016 - 06:20 AM
You guys might look into the FX flywheel as well.
  • trailrydr9
Posted June 01, 2016 - 07:51 AM
Doesn't look like it would work. At least that is what Motorcycle-Superstore and RMATV are telling me. Maybe too shallow of a case/cover? It's a shame to, cause the 9.21 oz is almost half the cost of the 4.4 oz flywheel weight.
Edited by trailrydr9, June 01, 2016 - 07:56 AM.
Posted June 01, 2016 - 08:21 AM
The 9.21 is for the Gen2 450, not your Gen4.  The price is probably fair since it's only half as big, and nowhere near as heavy as your stock one.
  • trailrydr9
Posted June 01, 2016 - 10:08 AM
See and that is what google gets me.  Took me to the 9.21 oz flywheel weight, and when I searched it as the 450fx, turns out that wasn't the right flywheel weight for that either...My Bad.
Edited by trailrydr9, June 01, 2016 - 10:08 AM.
  • cowboyona426
Posted June 01, 2016 - 10:43 AM
Now that you mention it I remember reading that the side cover was widened slightly on the FX to accomodate the larger flywheel.
  • 5 replies
  • Hot  33 replies
  • Hot  36 replies
