450FX clutch switch bypass plug
7 replies to this topic
  • cowboyona426
Posted May 25, 2016 - 01:52 PM
How many would be interested in such an item?  A simple plug you can install to bypass the switch in the clutch perch if you damage it or run an aftermarket clutch perch that will still allow you to use your e-start in gear.
Posted May 25, 2016 - 02:10 PM
Don't want to dump on the idea, but I wouldn't pay much for something I could make from 2" of wire and a couple of terminals.
  • cowboyona426
Posted May 25, 2016 - 02:19 PM
Not looking to get rich doing this, just thought I'd see if there was enough interest to warrant buying some parts to assemble them.
  • Not sponsored
Posted May 25, 2016 - 02:51 PM
All you have to do is remove it from the perch and the starter will engage in gear with the clutch in or out.
  • jwilson32
Posted May 25, 2016 - 04:26 PM
Yup, I was worried too when I put a WC clutch on mine, but it starts with no problem! :)
  • NB061
Posted May 25, 2016 - 07:53 PM
You can just remove it from the stock perch. If you want to keep your stock setup and/or have a neat fit that's plug and play they have them.
http://www.ebay.com/...Q5XQIWr&vxp=mtr
  • cowboyona426
Posted May 26, 2016 - 05:55 AM
Same concept but I wouldn't be asking $15...
  • foggy3061
Posted May 26, 2016 - 11:35 PM
With a couple of new Sumitomo connector terminals (plus seals) and a short piece of wire it’s an easy job to make a bypass using the existing clutch switch connector housing.
  • Hot  38 replies
  • Hot  30 replies
  • Hot  47 replies
